Fog or spot lights
Faisca
Pedro
Faisca747
Ford Bronco
Need some advice from you experts.
Should i install fog lights or spot lights on the front bumper of my Wltk?
I occasionally drive on some bad surface roads and some trails with opposite traffic as well, no fog here where i live.
Which would be better to light those bumps and holes on the road/trail?
Any brand you would recommend?
Thanks for the help.
Ford Bronco Fog or spot lights IMG_4881
Tarheel_Wes
Wesley
FJ
Your mod bumper has room for a fog and a spot (or combo) light
I have both on my bumper.
Id go with @Diode Dynamics
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
I have driving and two fogs. Fogs are basically floods. I’d say driving or combo as they are kinda both.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Diode Dynamics in mine. 3" spots white, 2" sae fogs white, 2" sae fogs yellow.
Skezzo
Ben
SRQ
Range Rover
IMHO no need for front fog lights.
When the fog is really dense I am missing the rear fog light way more than the front ones.
dejones64
Dan
MN
My Bronco is recovering from hitting a deer, so I need to watch more closely now. I also have 4 ditch lights that are not SAE, so I have the SAE white fogs that give me wide view when I have to turn off the ditch and spot lights. I use the SAE yellow fogs to help in snow/rain/fog.
I do plan on adding some rears, especially for backing up.
Billnchristy
William
Georgia
Fogs do an excellent job of lighting up the sides too.
If doing SAE go with the DD driving and white fogs if you don't care about SAE I'd say a combo and a fog or flood.
I did DD3 pro driving, dd2 pro white fog, dd2 pro amber fog in ours
Ford Bronco Fog or spot lights Screenshot 2023-01-20 065407
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Go with one of our triple fog kits. You can then have fog AND spot lights so you get light for every occasion.
Baja Designs and Diode Dynamics are the best kits and our brackets (KR Off-Road) are made here in the USA. All of our kits include 3 pairs of lights, our USA made brackets and our wiring harness (which makes installation VERY easy)
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/fog-lights/
Baja Designs Triple Fog Light Kit w/KR Off-Road Brackets for 2021+ Ford Bronco (HD Modular Bumper)
https://www.4x4truckleds.com/baja-d...-w-kr-off-road-brackets-for-2021-ford-bronco/
Ford Bronco Fog or spot lights 1674587163357
Baja Designs Triple Fog Light Kit w/KR Off-Road Bezel/Flush Brackets for 2021+ Ford Bronco (HD Modular Bumper)
https://www.4x4truckleds.com/baja-d...ad-bezel-flush-brackets-for-2021-ford-bronco/
Ford Bronco Fog or spot lights 1674587183399
Diode Dynamics Triple Fog Light Kit w/KR Off-Road Brackets for 2021+ Ford Bronco (HD Modular Bumper)
https://www.4x4truckleds.com/diode-...-w-kr-off-road-brackets-for-2021-ford-bronco/
Ford Bronco Fog or spot lights 1674587199635
Diode Dynamics Triple Fog Light Kit w/KR Off-Road Bezel/Flush Brackets for 2021+ Ford Bronco (HD Modular Bumper)
https://www.4x4truckleds.com/diode-...ad-bezel-flush-brackets-for-2021-ford-bronco/
Ford Bronco Fog or spot lights 1674587212978
WarthogJr
'21 Bronco Black Diamond
Yes.
Ford Bronco Fog or spot lights FB6BAFE4-1638-4E1B-8719-A95BC7044813
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
I installed the Oracle triple fog lights on my Badlands with the mod bumper. I do have quite a bit of fog where I live. The lights are great for that. We alos have some of the worst roads anywhere so I use the lights to illuminate the road immediately in front of the Bronco. Oraacle said that to be DOT compliant you should only run one of the three lights on each side. This would require cutting the factory wiring and then use two switches in order to have all three lights on each side lit. I did not do that and occassionally I will get the High Beam flash from oncoming cars.
