Here is what I know about hitches. Hoping that you may help me understand what I am missing and also answer my questions:
1. In the aftermarket, there is the long Draw-Tite hitch that extends under the tire or the short/flush Curt hitch.
2. BOTH can be installed without touching the bumper and without a lift.
3. We should NOT install them with the screws backwards. Better to be patient and finagle the screws diagonally near the muffler.
4. Both require a torque wrench. But which torque wrench should I get? Does the wrench need to be short so I can still install without lifting the vehicle? If so, can I get enough leverage to install them? Any recommendations on buying one? Or should I try to rent?
5. The Draw-Tite hitch should work with most bike racks, since it will clear the back tire (that is all I am using it for). The disadvantage is that it may cause shin damage (to me) every time I go to the Costco.
6. I did come up with a potential solution after some searching. It is called the Weathertech Bump Step. It will also help protect my vehicle from other people parallel parking behind me and will help me get easier access to the roof. Source: https://www.weathertech.com/bumpstep-original/. Has anyone used this with either hitch?
Thanks for your help!
