HELP!! Rear fender flares staining/ cant get clean!
Patriot
Illinois
2022 bronco 2021 jeep gladiator
I have a 2022 outerbanks and can not get the spots of the rear fender flares!! I tried everything from bug tar remover to rubbing compound and everything thing in between! I seen solutions for the black plastic flares not really any for factory painted flares! Any advice is appreciated. God bless America and Happy safe 4th of july🇺🇸🇺🇸🇺🇸🥃🍔🌭🍺
Patriot
Patriot
Illinois
Yes no luck 😂😂
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Have you tried white vinegar? Try a small spot to start.
Trino351c
2022 Bronco, John Deere Tractor, Snowshoes
Trying cleaning it with Dawn dish soap. If that doesn’t work then use a micro fiber towel with a small amount of acetone. do not pour acetone on vehicle.
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
Wait what? Acetone removes paint. I guess it will remove the spots.
So what are the spots? Actual stains from tar? Or are they chips in the clear?
I don't know what will work, but it's possible hair dye developer 40 might work to bleach it out. I've used it on old yellowed plastics to brighten it. Coated it in the developer and placed in a ziploc bag overnight. I would probably consult the body shop at your dealer first. This seems odd
7.3ltr bronco
Chad
Schereville Indiana
01 f350
Take them off and put fender deletes on. Or try a clay bar I've gotten some pretty nasty road grit off with a clay bar
7.3ltr bronco
Chad
Schereville Indiana
01 f350
Steel wool and some linseed oil. That will take it right off. Better try a test spot first just to make sure. 😬
Ground_zero298
Scs michigan
If you’ve put that much effort into it with no results I’d be taking it back to the dealership and asking them wtf. Then ask them to show you how to clean it.
7.3ltr bronco
Chad
Schereville Indiana
01 f350
Do you park under trees. At work or at home. My f350 sits outside in front of the house and gets those spots. Are a bitch to get off. It's some shit the trees kick off. I just take it to the car wash and boom gone.
7.3ltr bronco
Chad
Schereville Indiana
01 f350
I've used goo gone to get it off. But try a mothers
Ford Bronco HELP!! Rear fender flares staining/ cant get clean! 1656631293374993125371
clay bar you can buy it at AutoZone or whatever you got local. Have used it to get road tar from repaving that wasn't dry yet.
AK SNO RIDER
Ty
Alaska
Without knowing what it is it's hard to say what will work but I would try these products/methods one at a time.
CarPro Spotless
CarPro TarX
CarPro IronX
Clay Bar
Machine Polish
