WadeWolf76
Damon
Kansas
15 Wrangler JK Willy's, 67 Ford Mustang coupe
Ford Bronco Hennessey VELOCIRAPTOR Supercharged V8 Swapped Bronco announced 200
Pancho Kornwallace
Pancho
Mustang
Buy a Bronco and a Mach-E GT (or Mach 1, if you insist on an ICE edge) for under $100K.
The Mach-E (or Mach 1) will beat $225K Bronco 0-60 and you will have total seating for 9-10 instead of 4.
gryphon1231
dj
Miami FL
na
Just received from Hennessey. VELOCIRAPTOR Supercharged V8 Swapped Bronco -- 5.0L V8 750hp with 10 speed auto. 0-60 in 4.5s
Ford Bronco Hennessey VELOCIRAPTOR Supercharged V8 Swapped Bronco announced 1603985757516
If Hennessey can get a V8 to fit in the Bronco's engine bay then why can't Ford?
Lowcountry Bronco
William
South Carolina Lowcountry
I was going to comment that Velociraptor should stay an F150 Raptor thing and they should come up with a Warthog name.
But I'm racking my brain and can't come up with anything that makes "Warthog" cool.
The Pumbaa?
Ford Bronco Hennessey VELOCIRAPTOR Supercharged V8 Swapped Bronco announced OIP
Fordboi
Cameron
Murica
1966 Ford Ranchero
The RAM TRX does 0-60 in under 4 seconds with only 702hp and weighing in at 6400lbs. With more power and a thousand less pounds, the Bronco should be able to do mid to low 3s.
The answer is that they're making all of this up.
view @Laminar's post
LSBronco13
Lee
Louisiana
Chevy Tahoe
With those numbers it makes even more sense to purchase a GMC Hummer. Obviously Hennessey didn't watch the role out.
ApexCars
Fort Worth, TX
Ram 1500
Why would they but Boss stripes on it. What does it have to do with the Boss?
Zero_chance
JD
AZ
www.southvalleymustang.com
17 Mustang
What will happen first? #1 they take your money and don't deliver the Bronco. #2 the actually build one and it burns to the ground.
750hp S/C V-8 attached to a 16gal fuel tank might make it around the block.
I get 20MPG average in my car with the exact same power level, tank size and engine, you don’t drive around in boost all day unless you’re an idiot.
Compta38
Alabama
Ford Fusion
just cancelled my reservation and am getting one of these instead
LandCruiser
Bocephias
CA
Probably because he doesn't give a damn if you're killed in a car accident when the engine interferes with front crumpling or just outright enters the cabin.
Washington
1969 Bronco, 2002 Tacoma, 2015 Wrangler
Sounds fun for sure, but what about interior and top colors?
