Hidden Feature of the 7MT : Low speed cruise control!
jasonkosi
Chilliwack, BC, Canada
Was driving home the other day, most of my commute is on the highway but due to snow and freezing rain the traffic was stop and go. I found out that by leaving it in first gear, the Bronco will happily putter along at a steady 7kph (~4mph)at engine idle speed. No throttle input, no clutch hop. Do the same in second and it’ll sit at 13kph (8mph). No need to accelerate only to have to brake and clutch in.
Even though I was stuck in slow moving traffic for the better part of half an hour, I only touched the brakes a handful of times. Thanks, 4.46 gears!
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
In pre-pandemic times I used to do this daily in my Ford Focus (yay traffic). If the engine has enough moving inertia at idle it can move the vehicle forward once you engage the clutch without the throttle.
Kind of surprised it works in the Bronco though... very common with compact cars since they are so light, but on larger vehicles usually the inertia can't overcome the weight of the vehicle.
jasonkosi
jasonkosi
I think in the Broncos case the low gearing helps to overcome the weight
Richtor
Sonoma County
20 Tremor 7.3, 21 Badlands Sasquatch Stick(order)
I thought all manuals were 4.7 gears?
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Think that’s why it’s called Crawler gear.
one800higgins
VW GTI
I’ve only ever driven manuals my entire life until this Bronco. I was able to do this in all of them.
Roger123
Roger
VA Beach, VA
