- Ryan
- Feb 8, 2023
- 16
- 259
- 474
- Gilbert AZ
- Website
- shiftsandgrinsfabrication.com
- 2023 Badlands, 2022 Bronco Wildtrak Sas
- Badlands
You can't go wrong with an ADS Suspension setup on these. Especially since we take the time to get you build specs and weights and make sure you get the right spring rates out of the box the first time.The HOSS 3.0 Fox’s are soft in the rear… It squatted a lot for me on acceleration in Sport and would even bottom out hitting it hard, especially after adding LOD rear bumper/tire carrier. This in-turn impacts cornering/leaning in turns as well. Add any weight whatsoever and it floats around like an old Cadillac and you’re constantly riding in the stiffer part of the progressive spring.
Adjustable coilovers are the best option. My ADS fixed the squat and made it more planted, but I can adjust that feel too. I can easily adjust height and compression on my ADS for a more level or raked look, as well as increase the compression for added weight or more spirited off-roading. This works great for camping trips where I’m loading up 300-400 lbs of gear and I can just bump up the rear 5-6 clicks. Yet, I still get amazing flex.
However, if you’re not needing that level of performance, I‘ve read a spacer in rear and spring perch in front is best. You need to keep the geometry the same in the front via the perches, or with a small spacer/perch combo like the new Zone I believe does So you don’t exceed the allowable droop. Then the rear can handle the spacer and get you extra travel, it can handle the droop. But, you can’t just add a spacer in rear, that will cause a ton of rake and throw off the handling. Perches in the rear are fine too, but don’t gain you anything and with either of these you’re messing with the “sweet spot” Of the Fox’s. Eibach was coming out with HD springs, but I believe they also lift, and Dobinson had some heavier springs that were supposed to work, but I think they also lifted. Might check them out.
A lot of people say they can’t feel a difference in ride with the spring perches, and maybe their butt-o-meter is different than mine… However, given the progressive rates and how sensitive they are in their tuning, I didn’t see how I wouldn’t notice given what I experienced with the added armor weight. You’re going to be out of their “sweet spot”.
Even with playing with the coil over height and compression on my ADS, I can tell a difference in how the Bronco steers and handles. It handles best with at least a little rake given how Ford designed it, at least to me, and I run mine with only .25-.5 rake, but I can tune this at anytime with my setup…
https://shiftsandgrinsfabrication.com/product/productads-arizona-desert-shocks-bronco1296/
