How much will it cost to install 35 inch wheel aftermarket
kkurni
WA
Mini Countryman
Planning to remove sasquatch on OB order to speed up the build date.
How much will it cost to upgrade to 35 inch wheel aftermarket and 2" lift?
I am not handy man, do you think discount tire or costco can install this wheel with a gurantee later?
Bigkansas
AUSTIN
Topeka ks
Wheel!? Ummmm probably alot!
kkurni
WA
Mini Countryman
Probably when I need to change my tire after 2 years
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
Are you going to take your Bronco off road and what do you consider off road?
kkurni
WA
Mini Countryman
Just some light offroad that mostly other car can do easily as well.
But probably less than 10 times a year.
Does it impact the warranty of you upgrade your wheel your self?
HPNQ420
Wauwatosa, WI
If that is the case 32” tires will be fine. Option in the rear locker and put on a good set of 32”-33” tires. No need for rims and about $1000 for tires. You have no need for 35” tires, and they will decrease every aspect of pavement performance.
kkurni
WA
Mini Countryman
I just like the wider tires. Like adding a negative offset looks.
Can I just add a negative offset without changing the wheel?
Do you think discount tire / costco can do this?
broncbeau
Beau
15 Sierra
Changing offset you need to change your wheel. If you add zones 2" level and 35 12.50s it's probably about 2grandish. Discount won't do level installs. Costco probably won't either. But Goodyear will. Good luck dude.
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
Bora spacers or Spidertrax spacers. Boom got the hella flush look you want at a low cost.
BroncoTPA
Tampa
Give or take 2,800 to 3,500 depending on what wheels and tires you go with.
