How to remove automatic transmission shift knob?
tswillys
Todd
2022 Bronco
Does anyone know how to remove automatic transmission shift knob? I want to replace boot with custom one.
Thanks in advance for the help
da_jokker
Jeep Wrangler JKUR
I'm not sure if it's what you're asking for, but Mabett has a video on how to install their wireless charger.
In that video, they actually disconnect the shift lever. (IIRC)
Rspayde
North Ga
2022 C/O Black Diamond
It is the same set up as the ranger you just need to unseat the cover and peel it over the sift knob to reveal a single screw. Remove screw and then it should all come off.
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Buttercup had a utube video on installing the wireless phone charge. I used this to remove my center console when putting in an unswitched 12V outlet. 2 screws on the knob facing the dash. One tip that wasn't mentioned is chock your Bronco and put it in neutral - getting those little set screws in and out without doing that is a little difficult. I ended up scratching my hand in removal, and figured that out when I put things back together.
tswillys
tswillys
Todd
2022 Bronco
Thank you guys for all the help!! I got it out tonight. That's why I love this group, everyone helps each other out with our projects. :cool:
