If you're thinking about getting aux switches. Get them.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
Get them. While I was able to get everything needed for under $200, it's still a pain in the ass doing it the right way.
60A breaker to an 8 gang fuse/relay distribution panel to the switches. Then a 40A breaker to a relay to another relay for the air compressor since the fuse/relay panel only had terminals up to 30A.
I don't fully hate it because I'm an electrician and I don't dabble much in small electronics like this so I'm learning, but I'd still rather not be sweating for half the day.
Austin26
Austin26
Austin
Houston, Texas
Oh and I took a flat piece of steel from a bracket and welded it to the top of the battery hold down, spray painted high temp paint, and it makes for an excellent mounting position for breakers. Before spending money on a nice aftermarket mount, consider this because it looks quite nice and is ideal in placement as it as close to the battery as possible.
Ford Bronco If you're thinking about getting aux switches. Get them. FE554F74-2AFA-4AA9-81B9-7960820906B7
Ford Bronco If you're thinking about getting aux switches. Get them. 6A5DFBF7-58D1-4FD8-B7BA-A101EA212694
Ford Bronco If you're thinking about getting aux switches. Get them. 4F0C0318-332A-4550-8A49-4CE67CCB75AD
swooshdave
Portland, Oregon
Mustang
What is that last picture? That looks like when I tried to rewire my house and there was a funny smell and things went dark.
Toasty
Anthony
Austin, TX
Bronco Wildtrak, Jeep Wrangler TJ
Looks like he welded a piece of steel plate to the top of the battery tie down.
PSUTE
Western Maryland
Sierra
Head spinning. No brainer to anyone who had to fish wires through an a pillar...
Austin26
Austin26
Austin
Houston, Texas
Always open to critique, what specifically do you mean?
Yes, this was meant for those that have not done that and were on the fence.
mrjking2000
Justin
Loveland, CO
2022 Bronco BadSasquatch, 2019 F-250 PowerStroker
that's a weird looking bronco dash.
broadicustomworks
Hanging Rock, North Carolina
Agreed. For the minimal upfront cost you get the factory-installed levers that go click, the nifty and ergonomic enclosure, all the wiring magic. Ready to go from day 1.
Or go through the time, struggle and expense to do something aftermarket and spend half a day cussing, sweating, skinning up your forearms to still not have the clicky levers (although Auxbeam makes some pretty cool panels).
Or you could go the 1978 El Camino route and just punch holes in your interior plastics with a chisel (or drywall saw works in a pinch) and install light up rocker switches. Crookedly. Wired-in using twist nuts and speaker wire remnants.
Choose wisely. We don't need to see a new thread titled "Wired up my ditch lights and now my radio doesn't work and horn blows until the battery dies"
*Not directed at OP. His install does the job and looks better than 95% of most DIY stuff I've seen.
Get 'em. Cheap, easy-button done. *Plus warrantied with your 3/36.
mrjking2000
Justin
Loveland, CO
the engine bay doesn't even match up to a bronco.
Gnomad
Harbor Springs
Land Rover LR3 HSE
some will say they'd rather have the spot to store their sunglasses. I thought it was well worth the money for cleanly installed switches and the wiring to the 4 corners of the Brocno.
Moto26
Tucson AZ
Visor clips for your sunglasses are cheap and easy to find. OEM Aux switches are worth their weight in gold…
mmorgan
South Carolina
2023 Bronco
I would say a 4Runner as it is a Toyota product.
