The B&O center channel is the same as rear pods and front dash in the base.Not in the BnO system.
What about the r/l speakers in BO, same as pod speakers in BO?The B&O center channel is the same as rear pods and front dash in the base.
No, the R/L dash speakers are different. The B&O center channel dash, and rear pods are the same as the 4” speakers in the base system.What about the r/l speakers in BO, same as pod speakers in BO?
Awesome. Thanks so much for that pic.No, the R/L dash speakers are different. The B&O center channel dash, and rear pods are the same as the 4” speakers in the base system.
I would not skip the center channel in a speaker swap. In fact it’s the workhorse speaker especially in surround mode, and it’s the garbage paper cone base speaker.
Here’s a pic I have of the dash R/L
My mistake. I must have misread the post that I linked.Not in the BnO system.
Thanks. This helps me understand the total audio picture.From another thread... BnO take offs excluding the center channel.
I agree with RollSound, probably comparable. Either choice is going to be a big upgrade over stock.So, with a blend date and window sticker now in hand, I am going to move on ordering some upgraded speakers. Does the original poster or anyone else have an opinion strongly one way or they other between the Infinity speakers and the Kenwood
KFC-1066S available through Crutchfield. Similarly priced (inexpensive) speakers.
Not an audiophile, so not great at interpreting the tech specs. The Kenwoods are 4ohm impedance vs 3 ohm for the Infinitys. The infinitys handle 35 W RMS, and the Kenwood 21. 88db sensitivity on Kenwoods vs 92 on Infinity. Frequency response 75hz-21khz on Infinity, and 50hz to 22khz on Kenwood.
My guess is that these are probably pretty comparable but just wondering if anyone has strong thoughts one way or the other. Thanks
Have you confirmed this? I've seen three posts where folks couldn't get their center channel speaker grill off.The B&O center channel is the same as rear pods and front dash in the base.
Yes of course. If I say it’s a cheap paper speaker it’s cuz I know it’s the same cheap paper speaker. If you read the next post you will see I told that guy how to get it off lol.Have you confirmed this? I've seen three posts where folks couldn't get their center channel speaker grill off.
A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
So I finally got the adapter(vlinker) and tried out Forscan. The household pc was unavailable(wife took it to work), so I even got it running on my mac w/ the crossover app, thanks to some helpful posts.
Tried all the different mods indididually and combined:
380B & 3800 on 727-01-01
0900 & 0001 on 727-01-02
I’ll say it is very hard to compare the before and after differences when you make a change. The volume and fader reset, and seems like you have to input settings twice to take affect. Maybe just a slow reboot of the acm? Also trying to figure out the phone vs audio volume workings.
Anyway, the factory “tuned” as-builts sound slightly better to my ears right now. Supposed to get my s40 rears this afternoon. I’ll try again with those later. Already have them in the front.
Remember, that when fading to the rear in any amount,, you lose low end frequencies. The Low frequencies are tied into and married to the front speakers. So when you fade to the rear, you lower the rich bass most of us are chasing so hard to get anyway. Attenuating the front would be better. Mine would be balanced and sound better with more rear sound, but I had to center the fade because it was taking away too much low end.So I put the s40s in the rear pods, big improvement in sound quality. I even faded to the rear about two clicks to get more out of them. Worth it!
Today I played around with forscan again.
Tried:
3800 and 3801 on line 727-01-01
Couldn’t really notice much of difference.
Tried:
0900 on line 727-01-02
This has got to be the EQ setting for rear. They are definitely getting the full frequency range now.
Tomorrow I’m installing a JBL nano under the driver’s seat. Gonna tap the front speaker wires at the ACM harness.
If I was going bigger w/ an amp and sub in the rear I think the rear pod wires would work fine as high-level inputs w/ the forscan eq mod.
