Installed BORA 1.25" wheel spacers on stock wheels
orion
Jeremy
17' F-250, 17' Explorer
That looks great! I have the very same tire and wheel setup and was seriously considered 1.25 Borlas. Do you have a pic that shows the poke?
That sort of looks like Big Bend in the pics?
Thanks!
Best pic I could come up with...
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
Primm907
NWA
Porsche Macan S, Panamera Turbo S, Cayenne GTS
I was told by Bora that these, due to their shape, should work. Only concern that was highlighted by another member is not getting a full 7 turns on the lugs in the front. I have these on order, I'll keep you posted if they work. Orion, what setup are you running? Looks like you've still got your steelies. What tires? Spacers?
Where'd you end up with the spacer situation? I'm considering a 2" lift on a non-Sas with the stock steelies. Figure it'll need spacers to run 35x11.5's.
Sstone14
Santa Rosa Beach Fl
2022 Bronco Black Diamond
They fit perfectly and there is really no rub at all at full lock. If you go for 315 or 35-I highly recommend the 3/8 spacer from bora. No trimming of studs with the 3/8 which is great.
Ford Bronco Installed BORA 1.25" wheel spacers on stock wheels BCCBD1D9-0A38-451E-9AD4-1A65C0A9D0F5
Ford Bronco Installed BORA 1.25" wheel spacers on stock wheels 00D711CF-43E9-4261-B7DD-04C39A477DE2
Ford Bronco Installed BORA 1.25" wheel spacers on stock wheels 845F1D24-2C2E-4927-BF08-8BA7B823CDFF
Primm907
NWA
Nicely done and thanks for the specific recommendation on the 3/8 size.
What tire size are you running? Mostly curious on the width.
Thanks!
meffie
Raven
'23 WildTrak
For those of you pondering wheel spacers, these are super high-quality, fit perfectly, zero issues driving at any speed. I have never run spacers, but figured to take a shot after reading many posts on this forum that had positive results. Here is what the poke looks like, stock Wildtrak rims with 37x12.5 BFG‘s…nice subtle stance!
Any clearance issues with on the studs hitting the back of the SAS wheels with 1.25" spacer?
I'm pondering doing the same for mine, but I was concerned with going 1.25" the factory wheel studs might protrude into the back of the wheel.
Thanks
LiftedPony
Sean
Irvine, CA
2021 Wildtrak 4dr, Porsche GT4, Porsche Macan GTS
Thanks
I am consider the same 1.25" Bora spacers as well and still can't find clarification if trimming is required for SAS wheels
meffie
Raven
'23 WildTrak
I ended up just doing 17x9 0 wheels. Perfect offset
LiftedPony
Sean
Irvine, CA
Ford Bronco Installed BORA 1.25" wheel spacers on stock wheels 20230520_074555
New wheels look great! curious to know when you had the Bora 1.25" on your stock SAS wheels, did you have to trim them to fit?
meffie
Raven
'23 WildTrak
If I was staying 35's, prob would've done -12,
I got the new wheels rather than doing spacers. Since I like you couldn't find a solid answer, I just said screw it
LiftedPony
Sean
Irvine, CA
I did some digging and found this other thread that someone installed 1" BORA spaces on rear wheels where the threads tend to stick out more than the front, and the photo shows with measurement that 1.25" BORA won't need any trimming. Hopefully this info will help anyone searching for the same answer.
https://www.bronco6g.com/forum/threads/1-5-wheel-spacers-on-sasquatch.28446/post-1207768
Earlybroncoboy
Wagner
Pa
22Bronco,76bronco,73bronco,06F250,96F250,97F350
Did your spacers or offest wheel negatively affect steering feel at all. More effort to turn?
meffie
Raven
'23 WildTrak
Wheels, didn't do spacers, and no, not in the slightest
