Intercooler restricted SSM 51961
flip
Phil
IN
www.ruxerparts.com
Fords
I've seen several discussions and been personally asked about moving the intercooler, modifying or removing the front shutters. Ford has recently released a SSM with codes related to restricted airflow across the intercooler primarily due to aftermarket bumpers. My assumption is they saw multiple cases of this code and were able to link it directly to the bumper.
They do not list the specific bumpers or say the bumper is the only thing that can cause these codes but it's evident the majority of instances had a common cause.
SSM 51961 2021-2023 Bronco Vehicles - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Codes (DTCs) P0096 And/Or P007B
Some 2021-2023 Bronco vehicles may exhibit an illuminated MIL with DTCs P0096 and/or P007B in the powertrain control module (PCM), which may be more prevalent in high ambient air temperatures. For vehicles that meet this criateria, inspect the front of the vehicle for the presence of an aftermarket bumper and/or accessories which may restrict air flow to the charge air cooler and surrounding sensors. Remove the aftermarket accessory and return the vehicle to stock and reevaluate. If the concern returns with the stock bumper/accessories removed, proceed to normal Workshop Manual diagnostics.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Interesting, thanks.
Installed high mount IC few months ago and deleted both shutters (IC and rad).
No visible MIL/CEL/SES lights to-date. Driven thru 105+ desert temps 80+mph for hours, coolant temp bar meter thing never goes over 4 lights.
***Currently bumper-less (working on a prototype), but all foam/ducting pieces installed and once bumper does go on, airflow to IC/rad should not change at all.
CarGuy
New Jersey
2023 Ford Bronco
Next on my list is to install an aftermarket inter cooler and get rid of the shutters. Intercooler shutters is an oxymoron.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
keep in mind coolant temp sensor displaying on the cluster has no connection to the charge air cooler temperatures
BigMeatsBronco
Allan
2021 FE 2 door
turn OFF eco mode!!! or better yet delete it. Who is actually aware the shutters are closed in eco mode????
more eco geeko stupidity.
