- Mike
- Apr 19, 2021
- 32
- 1,028
- 1,053
- Eatontown, Jersey
- 2dr 2.3 Manual
- Badlands
- Banned
- #31
@LethalPerformance , anymore info on the Whipple Intercooler?
Here’s all the info we have available right now on the Whipple intercooler.@LethalPerformance , anymore info on the Whipple Intercooler?
Will these KN Charge Pipes work with the Whipple Intercooler?
surprised Whipple didnt release their own charge pipes btwYes they will!
We have a big batch of K&N Charge pipes on order. They are a few months out last we heard though!
Ask Whipple? Frankly, I think I may just get the tune only. I watched a video where they did the tune and got 60 additional xHP and the intercooler added just 10 more.Will these KN Charge Pipes work with the Whipple Intercooler?
intercooler is to handle the heat generated from the extra power, weak link for the 2.3tAsk Whipple? Frankly, I think I may just get the tune only. I watched a video where they did the tune and got 60 additional xHP and the intercooler added just 10 more.
Gosh, want to avoid ecoboom. Probably too cheap to even get the tune anyways. Pretty happy with the Bronco 2.3l just as it is today. Thanks for that, though.intercooler is to handle the heat generated from the extra power, weak link for the 2.3t
Pretty sure tune without Intercooler led to Ecoboom
How much power (HP/TQ) did you get out of your Mustang 2.3?And this isnt my first rodeo with the 2.3
Gia the Ecoboost Mustang:
CFM Baffled Billet Valve Cover Breather Kit
MMR CAI
UPR Dual Valve Oil Catch Can
FFTec Charge Pipes
Synapse DV
steeda Throttle Body Spacer
Boomba Intake Manifold spacer
NGK 6510
FFTec Street Intercooler
Krona Catted DP
Turbosmart Wastegate Actuator 10psi
JDM Tuned using SCT4
Steeda: IRS Subframe bushing Rear Lower Control Ar Billet Vertical link Rear Diff Bushing Progressive Sport Spring Sway Bars and End Links (F/R for both) Bumper Steer Kit Stainless Steel Brake Link -
Koni Adjustable Shocks
DBA 4000 XS Cross Drilled and Slotted Rotors (F/R)
Hawk Pads
Stock Calipers painted Red
Mishimoto: Coolant Expansion Tank Radiator Radiator Silicone hose Oil Cooler
RTR Grille+LED American Muscle tints
Diode Dynamics 4th Brake Light/Sequential Turn Signal/Side Marker/Switchback Turn Signal/Interior Lighting/6k HID Bulb
Raxiom LED Halo Fog Lights
regular dyno 311/373 before the downpipe and wastegate actuatorHow much power (HP/TQ) did you get out of your Mustang 2.3?
Problem is the mustang doesn’t use active shutters in front of its intercooler on the performance package, unlike the BroncoGood article on S3 about Ecoboost bolt ons
We did several tests with the new intercooler, to compare the charge-air temperatures. The intercooler was able to pick up 30whp and 11wtq with zero tuning changes!
New numbers = 275whp and 315wtq.
The stock intercooler was really holding it back! Compared to the peak of 173 degrees of the stock intercooler, the new CP-E intercooler kept the peak temperature down at 90 degrees. Keep in mind, it was 83 degrees in the shop! We also loaded the COBB Stage-2 tune as well, which is made to optimize a larger intercooler. It picked up a few more HP here.
We then went back and loaded the stock tune – just to see if there was any difference with the bigger intercooler on a totally stock tune. Even with the throttle being closed most of the run (due to the aftermarket intake), the car picked up 10hp in the top-end vs the stock baseline. This shows that even if you don’t plan on tuning the car, the intercooler is still a worthwhile investment for efficiency, cooling, and power.”
