- Jason
- Jan 20, 2021
- 7
- 1,376
- 2,860
- The Woodlands, tx
- 1986 Bronco XLT
- Outer Banks
You can offer me your email and I send you a installation guide.Whats the install like?
I’m also curious as to the install. Sending my email via PM.You can offer me your email and I send you a installation guide.
Please keep us posted if you run this for a long duration. I really want to know if the heat issue I have with the OEM charger can be fixed by this one. If you are running carplay or Android auto that would also be helpful info.. I just installed this. Pretty easy install. So far so good. I’ve only used it for 30 min so far. Will update if it’s a dud.
I think it’s in this thread. The first post in this thread. Are your setting blocking the first post in this the thread you are replying in?Where and how to order?
The fan won't run all the time. Only run when you are charging.Does the new unit fan on all the time? I don’t mind if this is a little noise but I will like to know if this will be on all the time?
also this work with magnasafe case? I used original bronco wireless charger before and you need to remove case to charge phone
Is there any sort of credit I can get for my existing unit? It is less than 3 months old and has only been installed for a little over 2 months. I still have the box and all packaging.Yes,sir.
. I was able to use this on a 4 hour trip a few days ago.Please keep us posted if you run this for a long duration. I really want to know if the heat issue I have with the OEM charger can be fixed by this one. If you are running carplay or Android auto that would also be helpful info.
