Mabett Introduces Wireless Phone Charger for Ford Bronco!
JPNC
Charlotte
2011 BMW 335i
Is there a difference between this one and the 21 off-road wireless charging pad?
OKST Bronco
Stratton Nolen
Mount pleasant, TX
2023 Bronco
@Mabett I bought one of the wireless chargers in early February and it is now completely dead. Lights flickered a few times yesterday morning and then went completely darkā€¦tried reinstalling/checked the fuse but nothing helped? Is there any way I can get a refund or a credit for the speaker pods instead? I would ask for replacement charger but it didnā€™t seem to ever charge my phone. Mainly kept it about where it was at when I set it down.
Love all of yā€™allā€™s products and this is the first one that has disappointed me :/
Mabett
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
You mean it can't charge the phone, right? Give me your Amazon order number and I can refund you directly, you don't need to return it
Have you purchased and successfully installed speaker pods, if yes, please PM me
SillyPosition
Silly
Israel
None
Why so many complain about its reliability?
On one hand I really want to renew the discount coupon @Mabett
but on the other hand the last few pages are filled with a few people complaining it stopped working. given the somewhat delicate installation process, swapping isnt that easy, so it makes me rethink if to have it or not.
Any explaination to it?
15W will really improve my daily experience compared to the oem charger.
Mabett
Mabett
Mabett
China
www.facebook.com
I want to get those wireless charging pads that don't work
najay
southern california
boss 302, focus st, gen1 lightning, f250 7.3l 4wd
I thought I bought this from your company but it looks like it was sold by Maxzina - are they the same as you?
najay
southern california
Another question - I just installed your wireless charging pad (I replaced the existing charging pad LUX package). There was already a separate harness for the OEM pad - do you plan on creating a separate harness that will use the wireless charging connector instead of teeing into the usb-c connector?
It would eliminate the need for a separate fuse.
najay
southern california
I bought the maxzina version and it stopped working. I am returning it to amazon, unless you are interested in it and want to work something out - I have until May 30 to return it.
The part numbers and FCC ID on the box are identical to the Mabett labelled product, so I am pretty certain this is the same as yours.
I removed it and it looks like the power and ground are almost shorted ... 4 ohms. It will not power up now. Was there a bad batch of these units that were released? Are the newer ones upgraded/revised or are you still shipping out the v1 units?
Mabett
Mabett
Mabett
China
www.facebook.com
I am upgrading my wireless charging pad, and I want to see if adding a fan will solve the issue. Let's see if it works.
Brocky
Bill
Maryland
2022 Bronco
Not fit Base Model!
Posted prototypes on my Facebook group about two months ago, and now they're here, in stock! Buy now!
Stay charged with the Ford Bronco Wireless Phone Charger designed exclusively by Mabett. Featuring a non-slip mat with easy installation and 15W power to charge, the Wireless Phone Charger is perfect for any sized device. Simply place your Qi-enabled smartphone on the center consoleā€™s phone tray for a quick and secure charge without cables.
Buy "Bronco Wireless Phone Charger" directly for $79.99 via this link: https://www.amazon.com/promocode/A1UZ95LLP3Y77G
UPS has delivered to Amazon warehouses, Amazon is transferring these stocks, although people can already search for them on Amazon and can buy them, but they can't be shipped immediately, I think this should be called "pre-sale" , you can click on the links of these products to see the estimated delivery time displayed on the page, I hope it helps you
Very low stock, only 50 sets, I'm still producing, the next batch will take next month to arrive on Amazon
Product Description
  • Support up to 15W Fast Charging
  • Ideal for Big-Sized Phones
  • Custom Fit&Classic Bronco Factory Look
  • Anti-skid mat keep the phone from moving around
Frequently Asked Questions
What is wireless charging?
Power is transferred wirelessly through a process known as magnetic induction which occurs between a transmitter coil (charging dock) and receiver coil (phone). This magnetic field generated by the transmitter coil induces a voltage in the receiver coil, which is used to charge your phoneā€™s battery.
What phones are compatible with the Bronco Wireless Phone Charger?
iPhone 8 or later, plus Galaxy: Note9, S9, S9+, Note8, S8, S8+, S7, S7 edge, Note5, S6 edge+, S6 edge,S6 and various Qi-certified phones from other manufactures can be used with the Model 3 Wireless Phone Charger. It is best to check your phoneā€™s instructions to verify its wireless (Qi) charging capability.
What is Qi?
Qi is an open standard which ensures the safe and compatible operation of wireless charging devices within its ecosystem.
Is the Bronco wireless Phone Charger is QI Compliant?
Yes. (Compatible but not Qi certified)
Will the Wireless Phone Charger work with phone cases?
Thin, non-metalized cases are supported. Large cases may not support wireless charging.
How is the Wireless Phone Charger installed?
The Wireless Phone Charger be easily installed at home. Please follow the installation instructions below:
What is included with the Wireless Phone Charger?
(1) Charging pad
(1) Non-slip mat
(1) Special adapter plug and wiring harness
How is the Wireless Phone Charger powered?
Charging power supply at the forward part of the center console
What is the power transfer output of the Wireless Phone Charger?
Mabett Wireless Phone Charge provides up to 15-Watts of wireless power transfer.
Is there one available to fit a 2022 manual transmission
Mabett
Mabett
Mabett
China
www.facebook.com
Onexl85
Bill
Dutchess county NY
2023 4 door Badlands
Purchased this wireless charger on Amazon, it doesnā€™t work
Mabett
Mabett
Mabett
China
www.facebook.com
OuterJersey
NJ
Honda, Toyota,VW, Lexus, Triumph, Honda MC
Mabett has outstanding service and stands behind the products. My only concern with these besides the hassle of installing and have to uninstall is the chance of a fire from suspect electronics. I have other Mabett products that are fine but this one makes me pause.
Mabett
Mabett
Mabett
China
www.facebook.com
We won't sell any products in the risk of fire.
