You have to take the full front end apart (grille, headlights, flares, lower trim piece and rad shroud) look up YouTube it’s very easy to do and takes at most 10 mins.@spiG Do you have any instructions on jumping the factory harness and leaving the hood latch unplugged?
I have a vacation coming up, and my biggest fear is being parked outside of a hotel and the alarm going off waking up people!
Removing fuse #20 worked for me a few weeks ago, but it didn't work when I tried it today? Any thoughts as to why? Do I need to leave it out for a certain period of time, do it while the car is off or only with the electronics on... Any help is appreciated. TIA.The only fix to this is resetting your modem by disconnecting it from power. You can do this either by pulling fuse #20 on drivers side fuse panel ( which I suggest getting a fuse remover/tweezer because mini fuse is pretty hard to come out ) or by disconnecting the battery for 5 minutes.
This has happened to me 3 times with little less than 1k miles on my Big Bend. Supposedly Ford is aware of this problem and will send out an update who knows when.
