Let's see your painted/powder coated Sasquatch wheels and beauty rings
MnLakeBum
MN and FL
ā€˜18 Range Rover Diesel
1 day of ownership and my shop was able to squeeze me in to get the new wheels and tires on my OBX non-Sasquatch. I bought these Sasquatch take-off wheels locally and had the trim rings powder coated. I'll be putting a lift/leveling kit in soon, we are still deciding exactly which one. It took them only 15 minutes to get the crash bars out on the fronts and get the wheels on. These Falken's are much quieter on the highway than I expected, not much different than the stock tires.
I went with the Sasquatch stock 315/70/17 tire size and I'm happy with the little bit of poke but I definitely need at least a 1.5" lift.
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Screen Shot 2022-04-15 at 6.12.20 PM
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Screen Shot 2022-04-15 at 6.17.18 PM
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Screen Shot 2022-04-15 at 6.17.30 PM
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Screen Shot 2022-04-15 at 6.17.43 PM
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Screen Shot 2022-04-15 at 6.17.53 PM
Robb
Robb
Oregon
2019 Camry XSE V6, 2021 2 door Base Sasquatch
Dropped off my rings yesterday locally to get them powder coated carbonized gray. Had to bring in my bronco as they wanted to match the color perfect.
hopefully ready by Friday, 30 bucks a ring. It was a pain to take them off but excited for the results.
steve_percy
Cypress
2022 Toyota Tundra 1794 4x4
I dont have Sas wheels, but given the opportunity for a new color I might suggest Cerakote. Even a heavy coat is WAY thinner. This can prevent compression chipping when bolting the ring back on. Made for firearms, which have tighter tolerances than regular car parts, Cerakote has come way beyond its standard black. I inherited my Dad's Browning T-bolt, back in the 60s the stocks were cured in salt, which later caused corrosion to the metal parts. Cerakote was cheaper and better looking to oreserve the original parts. And should hold up better to regular abu.. Use!
I think this is a great idea. I found a Cerakote authorized applicator in my area and called. Just $40 per bead lock ring (against $85 powder coating at a local shop) if I go with a simple color (e.g. silver...he said if I want to paint match Hot Pepper Red, it'd be more for the time experimenting...just like the powder coater said about 2-stage colors). Definitely going this way! Also gonna do the D rings and recovery loops. Should really make the wheels pop. https://www.cerakote.com/find-applicator
Ground_zero298
Scs michigan
Been looking at rims for months now. Finally got my oemā€™s detailed out. Think Iā€™m gonna keep the oemā€™s and step up to some wrangler mtr 37ā€™s.
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings D6E0CE60-86EC-4BD5-8025-AF0C2C583C35
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings D6250252-8DDD-4962-B2B8-EB0D678EE9E5
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings 3E851DB6-CE80-4C06-8C59-1E5E4BA84B9E
shoelessjoe
2013 Chevy Cruze
Where did you get those center caps?
Ground_zero298
Scs michigan
Those are the caps it came with. I just painted them. I air brushed them a candy red. High lights the silver color and not the black.
shoelessjoe
2013 Chevy Cruze
Pretty Sweet. Now I have to find some in Cyber Orange.
Cysquatch
Adam
Rancho Cordova, CA
2016 CTS, 1996 Silverado 4X4
Ixr
Honda civic
Dumb question but can you remove the beauty rings and drive without them on? I want to go the powder coat route but would need to leave the rings for a week or so and don't have anything else to drive.
Littlemule
Phillip
Cabot, AR
2012 Ram 1500 / 2011 Dodge Challenger
Yes, I drove mine around for a few days till the rings were done! Powder coated!
Ford Bronco Let's see your painted/powder coated Sasquatch wheels and beauty rings Bronco
kidkennel
Nate
NoVA
2014 JK
Did you buy black bolts? Have them powdercoated? I want to get my Badlands silver rings done but not sure what to do with silver bolts.
Ground_zero298
Scs michigan
Yes you can. They donā€™t do anything but protect the actual bead lock holes for the real headlock rings. They were first said to be helper rings but they didnā€™t help. Then they were reworded to beauty rings.
  • Like
Reactions: Ixr
Littlemule
Phillip
Cabot, AR
My Bolts were already black. Had to go back and look at the pic from when it was delivered and they are black.
