It really appears there is something going on with the susp on that bronc with 40's. Does not seem like the wheels want to stay planted on the ground when he gets into even a little bit.Not sure but I’ve watched them slip and slide through a number of videos now. They react terribly to the slick rock terrain. Embarrassingly bad actually.
Well you don’t come by a name like that by accident.I just keep shaking my head at BroncBuster breakin shit constantly. Its makes for good entertainment I suppose.
Some of that probably has to do with him being a manual. With a tire that size it can be difficult to modulate when you're trying to climb something. With an auto, it's a bit easier.It really appears there is something going on with the susp on that bronc with 40's. Does not seem like the wheels want to stay planted on the ground when he gets into even a little bit.
It also does not look like he is aired down much (is he even running double beadlocks?). I run 6-7 PSI in the rear, and 8-9 front on my 43's SX stickies. Even @ 6000 lbs, you don't need much air on that large a tire.
Good point, his tires looked to be bouncing wildly, like he had no shocks in it at all and the steering wasn't even connected. Maybe some of that is the independent nature of IFS. Looks very strange, but I guess I'm used to at least always seeing tires steering the same from solid axles, even when hopping madly.Some of that probably has to do with him being a manual. With a tire that size it can be difficult to modulate when you're trying to climb something. With an auto, it's a bit easier.
Yeah I would think with the sway bar disconnected it really lets each side do it's own thing. Like you said no axle to "tie" them together.Good point, his tires looked to be bouncing wildly, like he had no shocks in it at all and the steering wasn't even connected. Maybe some of that is the independent nature of IFS. Looks very strange, but I guess I'm used to at least always seeing tires steering the same from solid axles, even when hopping madly.
Some of what looks like steering input might have been either... a) the tie rod heim link bending, which to me was an obvious sign of abuse or b) the way independent suspension changes angles during travel. It looks too wild to be that, but maybe a little of both.Good point, his tires looked to be bouncing wildly, like he had no shocks in it at all and the steering wasn't even connected. Maybe some of that is the independent nature of IFS. Looks very strange, but I guess I'm used to at least always seeing tires steering the same from solid axles, even when hopping madly.
His gearing is way to high for 40s as well. At best he is at 94.75:1 with the manual. You really want close to 100:1 with 37s and a manual but 40s I would want even lower for slick rock. Autos are more forgiving do to allowing slip through hydraulic action.I like that Kevin is starting to notice the driving difference with an IFS, slower, more careful. And the part where he says " ask the Toyota guys and others they will tell you, carry spare rods " I would add, and axles, lol
Broncobuster posted a picture of is burnt out clutch on FB today, already went through one...I don't know the guy, but his rig looks like a Frankenstein rig... Too much of everything... Maybe a really good driver, but it sure looks from the videos so far, he likes that skinny pedal... Kudos though for finding all those weak spots.
You guys keep talking about this driver mod. Do you really not hard core rock crawl in rain, snow, and mud?I'm not trying to be a dick here or anything to Tyler. He's obviously getting after it. But I think some of the issues could be avoided with a more appropriate line and a driver mod stage 2
