MWILD
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
If you want to drive fast, buy a sports car.........not an SUV.
Hahah, I knew it was just a matter of time until someone made this comment.
My daily is a Model S Plaid…doesn’t change the fact that I want a more powerful Bronco.
Ford Bronco Little Engine, Big Power: My 2.3L Bronco Performance Modification Build IMG_1736
BajaBroncoLi
Long island NY
2022 Bronco
Did you get the new FSD update on your plaid? Made significant differences with mine
Ducati1098
What difference does it make? Just because it’s an SUV doesn’t mean you can’t make it faster.
A fast bronco is literally the best of both worlds
crenca
Southern New Mexico
I bought the Bronco for the great gas mileage, low NVH, exceptional build quality, and of course the the ease at which old and infirm get in and out...
I sleep through the night as well knowing if any of these things ever become a problem, my dealer will come through with amazing warranty service as well. I just can't understand why folks keeping asking @Ducati1098 all these questions 🤷‍♂️
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
This is great, I only wish you had picked a 2025 with the newer 2.3L MPC engine (same engine as the mustang uses) since I am waiting on a 2026 with this engine. It might be tough to know for sure, but some mods may work for both, while others only work on the older pre-25 engine. Maybe your next build!!
MWILD
MWILD
Oh, I wish I had an MPC motor. It’s too bad their ECUs are not cracked yet. Just hope it doesn’t take 4-5 years for it to happen 😩
When tuning opens up, they’ll rival the 2.7L in HP & TQ
https://www.facebook.com/share/p/1CEAteK5Fo/?mibextid=wwXIfr
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
following, since im waiting for the tuning!! id like a turbo upgrade too.
KreeHBronco
Kevin
Bay area California
Can't wait!! It is unfortunate that we can only get the manual transmission with the 2.3L. My guess is it has to do with saving money more than it has to do with limitations of the manual transmission's strength (I could be wrong). Another complication is I live in California so any performance changes are highly regulated. Still, looking forward to someday being able to upgrade my 2026 Badlands non-SAS, so my tires are 33". Even stock, with the manual, the 2025 I test drove seemed to have quite a bit of pep!
Ducati1098
Yeah I think there’s a lot that goes into it. Manufacturing costs, warranty costs, potentially the power level, it would require a completely different transmission case and potentially different clutch, slave, master, etc.
KreeHBronco
Kevin
Bay area California
Yes, that is definitely a possiblity but it might also require none-spec related changes to the manufacturing flow, costly stress/EOL analysis, a new power train layout ... which would be low on the ROE engineering NRE for a very limited number of customers who want a manual (management is likely to believe manuals are on their way out). My guess is having larger/heavier tires/weels, higher rear axle ratios probably result in larger stress/strain on the transmission/clutch than having a 20-30 percentage more horse power over a small percentage of the RPM range which is typically only seen while moving (higher RPM range). Then again I could be wrong.
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
Did you notice anything different switching from Ford DCT fluid to BG synchro shift II, as far as noise or operation?
