Looking for feedback on ceiling mounted roof lifts
Michigander
SE Michigan
SuperDuty
I am looking for feedback from people who have a ceiling mounted hard top lift.
I have a 9ft ceiling in my garage and plan to install a roof lift. I plan to remove the roof for most of the summer so I need to store the roof elevated to make room for the Bronco in the garage.
For those who have experience with them:
1) which lift was it?
2) pros/cons
3) did work well for "long term" storage (elevated)? How secure is it?
In my (limited) research I have found:
Smarter Home $995
https://www.smarterhome.com/products/hard-top-lifter-bronco
Lange $549
https://langeoriginals.com/products...-mic-hoist-a-top-power-hardtop-removal-system
J-Barr $449
https://j-barr.com/products/j-barr-ford-bronco-hardtop-removal-hoist-and-storage-system
Any others?
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
I have the Harken Hoist. I use it all the time to take the top off - it's a 1 person job and take mere minutes. And it's the cheapest option, around $270? They've been doing hoist systems for kayaks, canoes and Jeep tops for decades and have a great reputation for making solid products. The Harken Hoist is no exception - I use mine all the time in the summer. And because of our crazy weather I am putting the top on/off quite a few times and I am able to do both uninstall and install completely solo.
Poppavein
WA
2024 Bronco
I have no experience but I have an electric engine hoist I got from Amazon for $100 that I could use for this.
I originally used it to build a stairway lift for my old Lab.
I'm trying to figure something out myself, but like @NVCowboy my garage isn't tall enough. I have an outdoor car port I could use, but I'm trying to figure out how to keep birds out of it from there if I have it hoisted up, or critters from moving in if I have it down low. Not sure I'm gonna win that battle.
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
If you have an extra 8" above the bronco, you have the space... I back in to the garage, basically until my spare is against the wall. Lift the top from there 6". Then I normally park pulling in forwards and the roof section sits above the hood of the bronco.
You don't need tall ceilings.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
That would work, perhaps when the offspring moves out. Right now, the three vehicle garage has three cars. I know this is strange, but it’s all made possible by a stand alone workshop and several sheds. We joke about being organized hoarders. It’s what happens when you’re of German heritage AND have too much stuff. Throw in a little Irish heritage, and I can do everything with absolute precision, tomorrow.
dbattle
Northern VA
2011 Toyota Prius
Following. This is one of my Spring projects. So far I’m planning on diy with a winch that I’ll put in my attic space above. My question mark is what I’ll use to suspend it with. Just strong straps or a combination of straps and bars.
JonD
Jon
Maryland
Suburu Outback
Doing this as we speak. Straps next
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
I built a custom setup with my brother. I have 10' ceilings. I use deep strut to mount a Harbor Freight 800# hoist on the ceiling ( I toyed with recessing it, but found that I had enough space to leave it surface mounted).
Built a frame out of shallow unistrut with mitered corners (that's important if you want the 90* supports to bolt correctly (also saves some weight).
Used a center bar down the middle with 2 pick points (1 for empty 1 for full) so the frame always stays level.
Bought custom tie downs with 2" wide j-hook that's normally used for cargo straps - super heavy duty and way overkill - I aslo had to have them spread open in order to get the correct angle to grab onto the roof rack attachment points. This was incredibly hard to do and had them sent out to a buddy who had access to a 20 ton press - and even that was a challenge. The rear attachment is the balance point on a 4 door.
Then I added additional deep strut to the ceiling and 3/8 threaded rod coming down to essentially create a floating shelf from the ceiling. Once the top is hoisted I use 1x4 aluminum studs to attach to the threaded rod as the base of my shelf with big wingnuts and this supports the shelf to remove the suspension pressure off the top attachment points - with all the issues hardtops have had I didn't want to trust hanging the top for an extended period by just the hooks and attachment points.
I also extended the remote cable on the HF hoist.
https://photos.app.goo.gl/Eerm1DfNpW1yvwyw7
Ford Bronco Looking for feedback on ceiling mounted roof lifts PXL_20231104_220733739
