Mabett Mud Flaps Fits Sasquatch set that accommodates factory rock rails or tube steps
Mabett
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
orion1224
2021 Bronco Wildtrak 4Dr Sasquatch
Wait. What?
Are the "fits Sasquatch" mud flaps incompatible with 35" tires?
How can that be when every Sasquatch comes with 35" tires?
Mine arrive Saturday... and I have a Sasquatch. More info, please?
They work great on my Sasquatch with 35s. No rubbing. I only installed the fronts as I don’t want them in back for now.
Mabett
Mabett
Mabett
China
www.facebook.com
Mabett
Mabett
Mabett
China
www.facebook.com
Wait. What?
No, I didn't notice that the 35" tires were included in the SAS package, I take back what I said because the first person who helped me with the test didn't collide with the tires
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
Ok. So now what?
Do I install them just to find out they rub?
... or do I just return them in the packaging and look for something else?
Ugh. 😑
Mabett
Mabett
Mabett
China
www.facebook.com
Ok. So now what?
Ugh. 😑
I would tell people to keep installing because in my tests there was no friction, if it keeps happening I will explain in my link and figure out a way to fix the friction
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
I just wanted to clarify, will these fit without rub on a standard SAS with the stock 35’s? I watched the previous video and the tires look more aggressive than the Terrains on the stock SAS? I was planning on installing this weekend but will probably pass if there’s rub. Thanks for any info.
You should be fine, I have aftermarket wheels and NO lift (Non SaS) I will have the lift installed tomorrow so I will see if that resolves the issue. If you are SaS and stock wheels then I bet you have no issue!
Don't let my Video dissuade you I have a non standard set up.
Keerplunk
Izzy
Burbank CA
Wait. What?
MY Bronco is NON SaS Geez I think I stirred up a S**T storm by accident. I am on stock Big Bend Height with 8.5 Inch wide 17" wheels with -10 offset. My wheels poke a lot more than the SaS wheels I think the Sas guys an girls should be fine.
Keerplunk
Izzy
Burbank CA
Ok. So now what?
Ugh. 😑
If you have factory Sas then you should have no issue. I was commenting about stock height with 35" NON SaS
Mabett
Mabett
Mabett
China
www.facebook.com
thank you for the explanation
66GT
Thomas
Tacoma, WA
Ah. Ok. Happy again.
Why the hell does everything "Bronco" have to come with a dozen damn caveats? 😮💨
Keerplunk
Izzy
Burbank CA
Im building mine backwards! Wheels, then Tires, Then Lift!
Rootdog
Rob
Maine
Ram 2500
Great. Thanks for clarifying. Can’t wait to install!
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
So I had to abort my install. I have 35” BFG KO2’s on my wildtrak SAS suspension. My wheels are aftermarket and have a 0 offset. Full on contact at 3/4 Turn on both sides. Looks like these may work with a stock SAS setup but lots of folks, including myself, go for 0 or a negative offset and no way will these work.
I didn’t take a pic but the tires hit the honey comb pattern on the back of the flap. If these were flatter on the inside by a half inch it would likely clear
Gonna save and install on my wife’s Outer Banks non SAS this weekend.
MikeG
Charleston,SC
2022 Bronco Wildtrak
Just installed the driver's side... looks great. I'm having a lot of difficulty getting the expansion screw + nut removed... and somewhat hard to get the one back in that attaches to the mud flap. Does anyone have advice/trick for how to get them out more easily? Mine just turn and never unscrew.
I was having a similar issue getting them out, you need a small tool you can insert between the screw part and the outer ring to help it catch the threads. I used a tiny screwdriver. See this video, it helps explain it.
