MIC 2.0?
Sketchysilver
Essex, ma
Tahoe
So… I received my bronco on Friday, and am beyond exited. After inspecting the vehicle, I noticed that the seam, front 2 panels, on the top, were a little wonky. I posted pics the other day….I just received an email from FORD with a pic of my bronco “as it came off the assembly line”. My build was on 7/12, and it was stuck on Dirt Mountain until a couple weeks ago, when they supposedly replaced the top. If you zoom in on the pic from the plant, you can clearly see the uneven seam that matches with the pics I took the other day. How did this pass final inspection before shipment, and what should I do…when I brought it to the attention of the dealer, I was told, “it’s suppose to be like that” 🤷🏻‍♂️
Ford Bronco MIC 2.0? imag
Ford Bronco MIC 2.0? 7937000B-CBFB-43EA-9550-693DEC487C4A
Ford Bronco MIC 2.0? 4BC08C41-613E-4BAC-B9E8-12D800435D65
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Woah! That’s not right! Should be flush, that will probably leak like a SOB.
Ksjrb03
Tx
F250
Look at the rear cap screws. I bet the washers or something are installed wrong. And your Bronco looks wet/dirty. They are run through the final steps of the line after DM swap, your pictures were taken after swap.
