MIC Hard Top v2 Leaking
ahunter2
Austin
Tahoe
Wanted to see if anyone has had a similar issue and what resolution you had. I got my bronco 6 months ago and my roof has never looked right. Got in it last weekend and my roof was leaking by the aux switches and where the back roof panel connects to the back cap. The day before, I heard water sloshing around and I think it fell out of the trim covering the back C pillar. Dropping it off at Ford on Tuesday but wanted to see if this was a common issue. Thanks I’m advance
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Austin! I can look into your Bronco's leak concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Roger123
Roger
VA Beach, VA
We get water coming in out of the front air bags every now and then.
daddycreswell
Josh
Tenneessee
2013 Raptor, 1973 Bronco
I've gotten water from the driver side top airbag once, it was pouring and I turned. Only time I've had an issue in 7 months.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
There's a TSB for that. New seal and a shit ton of sealant.
Roger123
Roger
VA Beach, VA
It's only for '21's from what I see, not sure why it wouldn't apply to '22's as well, ours was built in Jan.
Hippydrome
Oregon
Defender NAS D90, 1995
I am about to have the new seal replaced again and just like you said they put a ton of sealant on it to the point that it oozes out and looks like a home made job as you fixed it yourself. The dealer said that ooze is normal and nothing they can do to make it look better. Thanks Ford!
Cheers,
HD
ahunter2
ahunter2
Austin
Tahoe
Thank you, just sent a message.
Roger123
Roger
VA Beach, VA
Cheers,
HD
Yea, it looks pretty easy, I'll probably just do it myself when it cools off a bit. I'm sure there's no reason to "overseal".
GeorgeS
Bristol, NH
2021 2-door Big Bend
My 2021 2-door just started leaking from the passenger side MIC window panel. The hard top was replaced last summer via and I've not had any issues until this morning. it rained all day yesterday here and I noticed water pooling on the ledge by the window. I saw water coming dow the window from where it should be sealed. I don't want to take it back to the dealer because its just too much hassle. Can I just put in a small bead of silicone sealant and stop it myself? I don't have time to drop and off and wait days to get it fixed.
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
Id
Id at least take it in and get it documented before u try fixing it yourself till they can get to it.
Brockdog12
NTX
2022 Explorer ST-Line
I've had the roof off mine a few times, no leaks as of yet. Took it through the car wash Saturday, inside is dry.
GeorgeS
Bristol, NH
Id
Yeah, I understand what you are saying. But this is so frustrating and I just don't have the time to keep taking it to a dealer. And I'm now in a new state and I don't have a relationship with any dealer. This is just very disappointing, especially since its been replaced.
GeorgeS
Bristol, NH
it leaks from the window. seems to be a seal issue. I think when they replaced the top, they had to put the windows in. I'm guessing there is something wrong with that but who knows.
doccoch
Doug
Midland, Texas
2019 Mustang Bullitt, 1967 Mustang Fastback
DM if you want to sell
