iBrad81
Brad
Cleveland
2024 Ford Ranger Raptor
The base stereos are probably better for upgrading purposes since you don't need the NavTV unit. One of the plug and play kits, the kicker 200.4 and 500.1 decent sub/enclosure, and a nice pair of front components and that is a great system. I would skip the factory B&O enclosure. The rattles are pretty awful stock and with an aftermarket sub are going to be terrible unless you dynamat the crap out of it.
That’s the plan, I like oem looking plus no room in the 2 door
Been in the 12 volt industry going on 20 years and started it doing audio
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Great! Thanks! I didn't know I needed to upgrade my B&O System until now. Stereo system was not even on my build spreadsheet...... Until now.
Crutchfield has always been a great source for car stereo stuff. Focal Speakers should be here tomorrow.
Thanks again........ Sort of.
Great write up by the way.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
Good luck. I would recommend starting with the front 3 dash speakers (those were the biggest improvement IMO) but the rears are so easy to swap out, I think it's a worthwhile upgrade.
I upgraded the front dash speakers last night and it was a huge improvement and only took me 45 minutes.
The B&O sub is terrible so I'm still deciding how serious I want to get with the sub and amp upgrades. Right now I'm leaning towards the MTI enclosure and amp rack with one of my old subwoofer amps.
Ford Bronco My B&O Upgrade Experience Screen Shot 2022-04-22 at 8.27.04 AM
Ford Bronco My B&O Upgrade Experience Screen Shot 2022-04-22 at 8.26.29 AM
rguest3
Raymond
I have ordered from Crutchfield several times in the past, so I thought I would give them some more business and order the Focal 4" Speakers to go in the Front Corners of the Dash and the two speakers in the Rear Roll Bar.
As listed before, the install is very easy and straight forward especially if you have the wiring adaptors and don't want to cut the original wire harness.
With just the Four 4" Focal Speakers installed there is a nice, noticeable sound quality improvement. Sound is more crisp and clear and sounds a little louder as well. For me, with how easy this was to install with solid results, it is money well spent.
Snowdogyyz
23 Ford Bronco Wildtrak
Where did you find the wiring adapters? The Amazon seller from the OP’s post is banned.
rguest3
Raymond
I found mine on eBay.
JL724
NY
Finally wrapped up the cleanup of the sub wiring. Updated pics in my original post.
Hernandezn17
Nick
Evo x
From my understanding with the B&o system you dont need to use the remote power? @JL724
