I figure the 2.3L makes about the same HP/TQ as my 351W in my 74'.
The SAE standard uses 93. Here in Kalifornia all we have normally is 91. I'll def put 91 in it and higher when found I never understand people who try to save $2-3 a tank by using crappy gas if they just spent 50k on a new car......Are the higher numbers with 91? 93?
Even the regular fuel numbers are up over the initial ones. I don't think either engine, no matter how you fuel it, is going to have any issues moving along.
I don't get it either. Some of my friends and family will drive miles out of the way to save 3-5 cents per gallon. Most of them aren't even saving a dollar per tank. When I tell them they burn most of that savings driving to a further station, they just look at me like I'm crazy. Whatever makes them happy, I guess.The SAE standard uses 93. Here in Kalifornia all we have normally is 91. I'll def put 91 in it and higher when found I never understand people who try to save $2-3 a tank by using crappy gas if they just spent 50k on a new car......
Difference here is around 50 cents between regular and premium, so a 2 door has a 16.9 tank would put it close to $8.50 every fill up. A 2 door squatch is going to be lucky to break 20 mpg so maybe 300 miles a tank and I'm lucky my commute isn't long and isn't allot of stop and go. The extra money isn't going to hurt me but I'll probably still test it out to see if it's worth the extra cost or even discernable.The SAE standard uses 93. Here in Kalifornia all we have normally is 91. I'll def put 91 in it and higher when found I never understand people who try to save $2-3 a tank by using crappy gas if they just spent 50k on a new car......
Some decal stickers can add as much as 5hp each...It amazes me that you can gain that much HP just by using premium fuel.
Had to do some sluthing but...Are the higher numbers with 91? 93?
J1349 | Ford | 2.3L GTDI | 2015 Mustang (w/Manual Transmission) – 98 RON Fuel |
EURO RON | US (R+M)/2 |
95 | 90.7 |
96 | 91.6 |
98 | 93.5 |
Also, pet dander and mowing your lawn are a lot more likely to cause an asthma attack. Reducing emissions is great, but it’s not going to eradicate global warming or allergies.China’s greenhouse emissions exceed every developed nation combined. COMBINED.
No doubt. Everyone on here hates the street truck thing, but i would love to see what could be done with that setup. Bronco lightning would be kinda fun. I would love to have both the BD i ordered and a base 2 door that was setup for the street. No 20s or lowering, just a 18 inch wheel/tire setup for the street that would stick.Wow. Pretty close in numbers vs the previous gen Explorer ST which was a 6.0 second 0-60. If Bronco is close to that... yeah that’s pretty damn quick for an SUV
The 2.7 base non squatch 2 door with some decent tires might be one of the best sleepers of all time.
It doesn't re-map. That would be replacing the existing tune with a second tune that is stored on another part of the ECU.Modern vehicles use a sensor to detect the RON of fuel in the tank (or blend), and re-map the ECU to run safely.
For all intents and purposes for a thread this basic, the concept of variables and specifics is overkill.It doesn't re-map. That would be replacing the existing tune with a second tune that is stored on another part of the ECU.
The existing tune combined with the sensors has programing that pulls timing and boost to put the engine in a state that keeps the knock below a pre-programmed safe level.
Absolutely zero, unless the bronco is re-tuned.
Hey, I said I had no problem whatsoever with tuning to increase power. But I draw a hard line when your tune increases emissions. America is a free country, but you have absolutely no right to harm the health of your fellow citizens.Don't think you understand what 90% of the tunes and mods are. But you do you...
