- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Checkout the latest offering from Grimm Offroad, in stock and ready to ship!
2021-2022 Ford Bronco Grimm ARB Twin Compressor Mounting Bracket Kit 10387
2021-2022 Bronco Grimm ARB Twin Compressor Mounting Bracket Kit Features:
Life behind the wheel of your 2021-2022 Ford Bronco is made much easier with an on-board air compressor system, especially if you plan on hitting the trails. Rough terrain requires airing down your tires for better traction and control, but once you get back to the streets, you are going to want to air back up to the necessary on-road PSI level. The ARB Twin Compressor is able to deliver that with output over 6 cfm of airflow, giving you more than enough air to handle your ARB Air Lockers, tire inflation duties, or power your air tools for any application you have in mind on the road or off of it. On top of its big-time airflow, the ARB Dual Air Compressor Kit is waterproof and built tough enough to survive practically any off-road challenge, making it the perfect choice for the avid off-road adventurer that needs and air compressor system that can handle the most brutal terrain on the planet. To properly mount this awesome air compressor system on your Bronco, you will need the 2021-2022 Bronco Grimm ARB Twin Compressor Mounting Bracket Kit.
Mounted Above RH Inner Fender Liner
The 2021-2022 Bronco Grimm ARB Twin Compressor Mounting Bracket Kit features four precision-cut steel mounting brackets that hold the two motors on the ARB Twin Compressor, while dissipating heat that is produced when running them. Each bracket is built for longevity with a black powder coat that adds extra corrosion resistance. To avoid any annoying vibration sounds when running the air compressor, these brackets are designed to resist vibration and deaden any sound for smooth and quiet compressor operation. Having this compressor on your build will go a long way in making your adventures safer and more prepared. Be able to quickly air up tires and efficiently operate air-powered tools and accessories with ease right from the inside of your inner fender above RH inner fender liner. This location of the compressor keeps it out of harms way and further helps to reduce any noise. Along with the brackets themselves, this kit includes new air line and fittings, a new braided steel hose that runs to the included bulkhead fitting for attaching an air coupling, and a wiring extender that connects to the compressor's standard harness.
Compatible Compressor: ARB Twin Compressor
Fitment:
- Precision-cut, high-strength steel mounting brackets for exterior mounting of ARB's Twin Compressor
- Easy to access air for airing up tires or setting up air lockers
- Much quieter than cabin-mounted air compressors
- Locates compressor intake filters at the top of the engine compartment
- Comes with brackets, wiring, hose, air fittings, and hardware
- Simplifies the ARB wiring harness installation
- All hoses, fittings, and hardware required for installation are included
- Backed by a limited lifetime warranty
- For Ford Bronco 4-Door & 2-Door Only
Fitment:
- 2021-2022 Ford Bronco 4-Door
- 2021-2022 Ford Bronco 2-Door
