dmhalka
doug
Audi
Tried searching for this answer but didn't see it. what happens if the airbags deploy? it looks like these are directly in the way of the airbags. are these designed to rotate out of the way? or do they become flying projectiles inside the vehicle?
Headsong
It's actually very simple. If that terrifies you then don't buy them.
FatRat250
Easton PA
22 Bronco Badlands Squatch Lux Hot Pepper
Ordered mine the install video on you tube falls short of connecting the optional run to an auxiliary switch after you have tapped the interior light circuit-any recommendations?
I ran mine to a aux switch in the overhead.
FatRat250
Easton PA
Watch their video - they wiring is behind the airbag and the light sits above the bag deploy point on the breakaway trim panel. No issue.
CyberOrangeBadlands
Joe
Long Island, NY
ā€˜22 Bronco
IAG mentioned they would be updating their install video to include the AUX connection - expect it this upcoming week.
FatRat250
Easton PA
@IAG Performance - these are excellent. Anyone who is on the fence - hereā€™s my 2 cents.
I ordered Friday - got an email they shipped a few hours later. Thought it was BS, but they sent a tracking number and they arrived the next day (yesterday) in a nice package - very nice package. Overnight arrival - awesome!
The harness and light quality looks first rate - well made and good insulation wrapping the harness. Iā€™m pleased.
Took less than an hour to install. Their video is perfect. Thought it would be more difficult - itā€™s mostly east as pie. More on that in a sec.
Very bright - way WAY better than stock.
so - hereā€™s my only concerns -
Tapping the power wire at the fuse panel is a PAIN. Hard to reach, harder to see. BE CAREFUL - there are two gray wires, (on mine anyway) one with a brown tracer/stripe, and the one you want- a gray with purple tracer. Under the dash itā€™s hard to see which is which - donā€™t get the wrong one - I almost did in my double check I saw the other gray wire. Woo - that was close!
Second- I have a soft top and a hard top. I figured I could get the cheaper set without the brackets. I was wrong. Even if you have a soft top, but have the hard top prep (with the black rectangular plates on top of your roll bars near the b pillar) you WILL need their brackets ONLY WHEN YOU MOUNT THE HARD TOP. No brackets are needed when the soft top is on, even if you have the prep kit. The lights are in the way of the hard top latches, the brackets need to be used to get them out of the way. Bottom line - hard top on, brackets on. That wasnā€™t clear when I ordered, but I take responsibility for that one.
I called IAG to get the brackets - left a message - (my lights are installed but hanging in position now until I get the brackets. But they are all working great)
I guess Iā€™ll report back on their service to see how long the brackets take to get. Based on my experience so far - I bet they will be good. Weā€™ll see.
No - I donā€™t work for or even know any of these guys - this is a well made, well packaged and easy to install product with simple instructions in the video. Keep you phone with you at the bronco and go step by step.
Thanks @IAGperformance.
as for connecting the lights to an aux wire, that was simple too. Thereā€™s a pigtail on the harness with a connector attached. Just run your power to that and donā€™t worry about the amperage - pulls so little draw almost any power supply will work. The lights are very efficient. I wired it to one of my aux switches. Works perfectly.
AK007
Washington DC
Awaiting my Bronco
I was so surprised how quickly it arrived, ordered 1/27, delivered noon 1/28. I'm guessing being 65 miles away from IAG helps lol
dmhalka
doug
Audi
Sorry, what's simple? Was that a non-answer answer? I'm not terrified of it, but do want to know what to expect if an airbag goes off. If you've never worried about that or thought about it, just move along. But I don't get the point of your reply.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Seems overpriced for what you get. That seems to be the case with a lot of aftermarket Bronco accessories. I think I will just save my money and continue to use my headlamp or flashlight instead.
Headsong
My point is that it's been asked and answered. Many times. Mostly in regards to the grab handles.... So if you're uncomfortable, don't order them. Simple.
EgreenBadSquatch
Washington
2015 F-150
Second- I have a soft top and a hard top. I figured I could get the cheaper set without the brackets. I was wrong. Even if you have a soft top, but have the hard top prep (with the black rectangular plates on top of your roll bars near the b pillar) you WILL need their brackets. The lights are in the way of the hard top latches, the brackets need to be used to get them out of the way. That wasnā€™t clear when I ordered, but I take responsibility for that one.
I ordered for the soft top also. I havenā€™t received mine yet but if these donā€™t work with the hardtop prep kit that should have been stated since most have that.
Ducati1098
Curtain airbags fire down, not out.
Ksjrb03
Tx
F250
They work fine with the prep kit.
Badlands77
Minnesota
2012 Ford Focus, 2022 Bronco Badlands
Can these be installed on the two door with just removal of the front roof panels without having to remove the back shell? (Cold climate here and not a lot of garage space)
