- Bradley
- Jul 19, 2020
- 30
- 695
- 1,341
- Hattiesburg MS
- 18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
- Badlands
Lets talk wiring it to begin with follow this
Now let's talk Aux switch. Yes many have showed other ways this is for the guy that needs someone to say do this then this. Not the guy that can tell me 50 different ways to do it.
OK lets get started
Watch this
Now you at least have an idea. Now what Aux do you want to use?
Now get that wire from under hood. Connect it to the White wire or the Brown wire white stripe it doesn't matter but if you or another person has used one use the other. To connect use a (Blue 14-16AWG connecter see pic)
Now after the wire is connected. Go behind the Glove Box. You will see both the white and Brown wire.
At this point you will need some wire run it from the drivers side fusebox to the wires beside the glovebox (Below are pics of how I did it). Once wire it run to glovebox connect it to the same color wire you connected outside white or brown with white stripe. Now go back to the fusebox side cut wire and connect it to the plug that is on the dome light kit for Aux. And you are done.
((See post 4 for another option ))
OK lets get started
Watch this
