OBXBronco22
Jonny
Clearwater
2022 Ford Bronco
Info to help add to AUX switches. Hope this helps.
Thanks, good video!
I converted the .75mm I would need to aux 6 to 18 gauge, but read somewhere that all the wires in the aux kit are only 16 gauge (so a bit underpowered for some accessories). I believe this below is the updated/corrected gauge of the wires.
Ford Bronco New Product Release: IAG Four Piece Interior Dome Light Kit with Harness F0040695-4728-4337-9A72-1448EA29A159
Am I right to assume that 16 gauge wire is sufficient for these lights to connect to aux 6 through the firewall grommet? @IAG Performance ?
smahones
Shane
Denver, CO
Ford Expedition
I gave up on trying to wire tap the gray wire. I tried.. thought I had it tapped successfully, but apparently not as the lights do not come on when opening the doors. There is just so little slack in the factory wiring. It was really difficult trying to get the wire tap clip on the wire. So I am just going to leave them as a manual on/off only on one of my Aux switches. Honestly, I am fine with manual only and all I can say is DAMN these are bright and really light up the interior.
Just FYI - I struggled with the lack of slack too. I cut the zip tie off the clip and removed the top of the clip - it releases on the rounded end below where the white lever settles when removed. It gave me an inch or two to play with and after two attempts got the wire tapped.
Headsong
So I'm an accountant. KISS...please. If all I want to do is run these on AUX1, I connect what to the yellow wire under the hood and the red power wire for the lights to the brown/white wire in glovebox?
Ksjrb03
Tx
F250
Didn’t think I would install them right away, but I did.
I’m no pro at mods and with following the instructions and being careful pulling panels off I pulled it off in about 3.5 hours. That’s with tapping into Aux Switch 6 using the grommet in the firewall under the steering wheel as previously posted in this thread.
They are very bright and well worth it to me. Thanks IAG for another great product…and instructions! @IAG Performance @IAG Support
I would highly suggest you run that wire through the grommet and not around it. This will eventually short out after the insulation wears on the body.
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
Thanks, good video!
Plenty sufficient. These are extremely low amperage draw.
OBXBronco22
Jonny
Clearwater
2022 Ford Bronco
Good because I just finished wiring them ! Ran a new wire through the middle of the firewall grommet into aux 6 (yellow-orange wire) and bam! Now I can flip them on and off. Love these.
Just pop the grommet out, poke a small hole in it and push/pull a wire through. Replacing the grommet from the inside was the easier path.
Headsong
So, you're NOT connecting it to one of the wires behind the glovebox? To just run on AUX..
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
I’m a master is disaster when it comes to wiring stuff in vehicles. Knowing my luck, the new lights won’t come on and the car alarm will start going off non stop upon completion of install. I’ll give it a whirl though and try to order a set Friday at next release.
Headsong
Yeah, exactly. Without beer!
RynoRanger
Chuck
Phoenix
azbluey.com
2.7L Badlands NS 4dr
@IAG Performance sorry if asked already - i'm assuming there's no interference with the airbags up there if they should need to deploy?
MSparks909
Miles
ENC
2014 Ford F-250
Run them to Aux 6 and save Aux 1 for higher amperage lights you may add in the future (light bar, ditch lights, roof lights, etc.
IAG Performance
IAG Performance
JJ
Westminster, MD
Correct no interference with the airbags since they fire down not out. Just make sure you run the wiring behind the airbags as shown in the instructions.
Headsong
But you didn't tell me how!! lol....
IAG Performance
IAG Performance
JJ
Westminster, MD
Our supplement video on how to hook up to your AUX switches should be done in the next couple of days and will walk you through it.
