They stick up a little bit, but I think they would likely still work with the mesh top.I have a JtopUSA mesh top under my hard top, do these lights stick above the roll bar to interfere with the mesh top or are they flush with the top of the roll bar?
Aux SwitchesWhat’s an upfitter switch? I’m kinda new to this
We'll have a rear light solution out in the future.It appears these mount for the front & back seats. What about the cargo are in the 4 door. Do you have the same type of light for the back? One a bit behind the rear seat, each side, and then one, each side, near the back of the truck. Most of the threads I read say it is poorly lit.
These look good for the passenger area, what about the cargo area?
same both sides of the truck?? Please don't make a single light as some have.We'll have a rear light solution out in the future.
Can't wait for this - SEND IT!We'll have a rear light solution out in the future.
Meaning it will be coming?Unfortunately it doesn't. The switch operates on a CAN signal to trigger the lights which doesn't work with these at the moment.
Not in the works right now, but maybe in the future. The aux switch is your best bet for switched control now.Meaning it will be coming?
Doesn't CAN use 2 wires? Do your lights tap into the LIN bus that controls the light dimming?Unfortunately it doesn't. The switch operates on a CAN signal to trigger the lights which doesn't work with these at the moment.
I have a soft top with the Ford mesh top in place. I just looked at it and these lights will fit just under it. Can't wait to get them. The mods will never stop, LOL!They stick up a little bit, but I think they would likely still work with the mesh top.
