NEW Wildtrak, 6.7 miles, check engine light on
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
This really sucks on a brand new vehicle. And any time you have to get your vehicle serviced by the dealer or anyone else I am starting to dislike even more than going to the dentist or Dr. All the dealers and shops are so busy- it's a waiting game these days just to get the vehicle in. Then it goes in and more waiting. Then can they even do the work right.......And the vehicles of today are so hard to work on yourself......
I feel so "gifted" that my 2022 2 Door Sas has been pretty good so far- no issues other than 1 recall for the windshield reseal and the front driveshaft (had to be replaced). All routine maintenance I do myself.
Mhguy
Greg
Reno, Nv
43’ motorhome, 14 Jeep jku toad, 2014 F150 toad
Absolutely agree! I opened the hood and it looked like something from the Space Station engine bay!!
YIKES!!
Ducati1098
Interesting idea. Wonder what sensor would cause 2 injectors not to fire?
fuel level was above 3/4.
I pushed open the flapper, in the fuel fill tube, and there was a bit of pressure in it, but I think that is normal.
now it’s a waiting game with the local dealer.
Unless 2 injectors went bad at the same time, which would be extremely rare, a wiring issue is the most likely cause.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Piggybacking on the possible wiring problem, OP did you or your buddy look under the hood for possible rodent damage to the harness?
Mhguy
Greg
Reno, Nv
I just picked up the Bronco. The dealer went through a full battery of tests and couldn't find a definitive problem. They took it on an extensive test drive to try and replicate the issue and it never did it again!
They did reload some software and cleared a couple of codes, but they really didn’t think they were causing the problem. Time will tell.
I drove it about 30 miles home, the last 10-15 miles, in a blinding snow storm, and it was flawless!!
Thanks to all of you, for your support and ideas!
Greg
