JP_Oracle
JP
Metairie, LA
21 Bronco
Then maybe the resistors are the issue for the signature lighting?
After all, there is no need for the added resistor in an LED assembly for a vehicle that has the LED assembly installed from the factory. Perhaps it's creating just enough that it thinks it's open now?
The resistor has a JST connector so it can be unplugged. This is not the issue for the Signature Lighting. Again, resistance is not the issue, it is the fault sense for the tail lights that operates through CAN.
As of now, turning that fault sense off with FORscan is the only solution to avoid a bulb error message on the dash.
Havoc1
07 F250, 20 Accord Sport, 21 HD
"Resistance is not the issue"
But it thinks it's open somewhere in the circuitry... anyway have fun with sales
RedHotFuzz
2022 Bronco Black Diamond 4D
Your local dealership or any shop that does work on your Bronco should be able to do the flash for you. It is a quick change in the menu, should take a technician less than 5 min to do it.
So $200 at the dealership. 😉
Djd7
Northeast
BD
thanks @JP_Oracle for bringing this to life! could you share a video of the turn signals activated?
‘21OBX
90Bronco19
2022 bronco outer banks
I agree they look nice, but that price point for tail lights is a bit steep for me. Ill gladly acquire anyones take-offs signature lights for $200
🤣🤣🤣 I wish you luck, they pricey! Heck I’d buy someone’s takeoffs just for spares if they are in that price range.
JP_Oracle
JP
Metairie, LA
21 Bronco
Here’s an iPhone video taken from the initial testing running through all functions. Sorry if not the best quality.
Headsong
As mentioned in a post yesterday, would sure love to have the ability to use those backup lights on a Aux switch when needed.
JP_Oracle
JP
Metairie, LA
21 Bronco
This is popular to do with the Jeep community. From my understanding, all that needs to be done, is run a wire from the AUX to the reverse light wire, then install a diode to keep current from backfeeding into the switch when the truck is in reverse.
Should be the same for the Bronco.
Cousin Eddie
Jack
Pennsylvania
Cadillac
is it just the angle the video is taken or does the left light look a little brighter than the right light?
JP_Oracle
JP
Metairie, LA
21 Bronco
Likely angle. They are equal brightness in person.
Djd7
Northeast
BD
I think it's because of the shadow / way the sun is casting.. even if it was off, wouldn't worry about it was initial testing and likely a pre-production version.
OracleLights
New Orleans, LA
www.oraclelights.com
blueoval16
Marcus
St.louis
6G Bronco
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Groupbuy is filling up! Be sure to get your order in before this deal is gone :)
Jen
Northern VA
21 Bronco BB 4D, '97 BMW 323ti, '90 Miata, '02 NSX
Ordered. Thanks for a product I didn’t know I needed but now have to have. 😉
