OEM Wildtrak Fox HOSS 3.0 vs Eibach Pro Truck Coilovers
budman
Louisiana
F150, Expedition, 4Runner & 2 Dr Bronco
I have a 23 2 Door OBX SAS that I'm putting an ARB Bumper/Warn Winch on and in doing that wanted to upgrade the shocks on my Bronco. I was leaning towards the Eibach Pro-Truck Coilovers for adjustability but have an opportunity to pick up a set of Wildtrak OEM Fox HOSS 3.0 Shocks. Just curious if I should even consider the Fox parts or just go with the Eibachs. Maybe one day in the future I'll jump from 35's to 37's but for now staying with the 35's.
ElonMuk
Keith
Phoenix, AZ
All the vehicles
If those are the only two options you are truly considering I would go for the Eibach's and some upgraded front upper control arms. Should help with the added weight of the ARB bumper, Warn winch. Best of luck either way
budman
budman
Louisiana
What other options should I be looking at? To the "Search" box I go! Should have spent more time there to be honest! Thanks!
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
The Eibachs do not ride as nicely as the Fox shocks but they do handle the added weight better.
PWillette
Parrie
Maine
Not sure how you use the truck but the HOSS 3.0 shocks are going to give you a better everyday ride. I have the Eibachs and very happy but they are a bit stiffer than the OEM Bilstein's.
Caleb@PandaMotorworks
Caleb
St Louis MO
+1 for Eibachs. Can't beat em for the price. They also have an upgraded front spring option to help with the extra load on the front end due to your ARB bumper and winch.
Id be happy to answer any other questions you may have! We also have a killer price on the Eibachs right now, I would be glad to hook you up!
Lak34ers
Troy
Seattle
I have a BAMF bumper and 10s Winch so extra 150lbs+. I took off my SAS and put on 6100s and they made an amazing difference. Highly recommend. jeepandtruckspart.com had them for about $800 for all 4. Used my existing SAS Springs.
ElonMuk
Keith
Phoenix, AZ
All the vehicles
It all comes down to what you are going to do with the rig. The Eibachs will help with the added weight vs the Fox 3.0 Hoss as you can go with a stiffer spring as mentioned by other(s) on here.
If it were me and you have the funds I would go with a 2.5 reservoir setup such as ICON, King or Fox (A/M options not OE options/ takeoffs from Fox). OME also has good options for rigs that plan to carry extra weight. as well
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
I have a 23 4dr Wildtrak with the HOSS 3.0 and ARB Summit. Go with the Eibach's. The stock springs on the HOSS 3.0 sag with the extra weight. It's not horrible, but you do feel the weight while driving.
Aonarch
North GA / MT
You are going to want heavier springs up front. I would not go with the Foxes.
Draughon
Daylon
Dallas
BMW 4-Series
Searchdawg
Kentucky
2015 Supercrew Platinum 4x4
Following…I have ‘23 Badlands Sasquatch and am adding the same.
budman
budman
Louisiana
Thanks again...
Purchased the vehicle for dual purpose. Giving my 16 y/o son my 2019 F150 in May and will use this as a daily driver and weekend fun chaser. I work from home all but 2 days a week in office and the Wife and I plan on taking her on some rides/trails along the Gulf Coast States, Arkansas, TN and eventually the parks in the Western States. Not planning on rigging for overlanding but will eventually add SOME other stuff to it. Our lab needs some space to ride so won't go overboard with it, at least on the inside so maybe add a roof rack system with an awning of some sort but that is down the line and not an immediate mod I'm looking at.
ElonMuk
Keith
Phoenix, AZ
All the vehicles
Thanks again...
If this is the case the Eibach's with some Aftermarket Upper Control Arms for the money should suit your needs.
I tend to overbuild when I do things but that is a personal choice.
Nanook
Jonathan
Sounds like you can’t go wrong with the Eibachs.
BUT don’t drive a Bronco with the factory Fox’s first tho!! 😛
