Oil cartridge install warning
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Doing my first oil change went to reinstall the oil cartridge and somehow it became cross threaded and the genius engineers at Ford thought plastic housing was a great idea.. Resulting in broken thread. With barely any pressure...
Ford Bronco Oil cartridge install warning EC2E1C4C-FFC9-412E-9AAF-CAD2554469FC
So if there are people out there like me.. Ensure that it's 100% seated properly.. Or its gonna run you 45$. And if u don't have a 1-32nd socket a 27mm will work.
Thank you for attending my Ted talk.
shimmy825
James
Los Angeles
2017 Mazda CX-5
Where did you get the replacement cartridge?
grayshadow
Charles
Humble, Texas
That’s why Ford should be changing your oil for free with your FordPass rewards points.
RHeinz
Ric
Houston, TX
Steel threads can also be cross threaded. It’s a user issue not an engineering issue. Since it’s an O-Ring seal, you could have probably trimmed the damaged threads and reinstalled it without any issues.
j_anderson
Fort Wayne, IN
www.instagram.com
I always start these (and any threaded bolt) by backwards spinning until I feel the thread drop then stop and twist the other way to tighten. Perfectly aligns the threaded object and prevents cross-threading
Wanted33
Down south in Dixie
I see a big problem in the making here. Most deaers hire just out of high school kids, and teach them the simply process of changing oil. However, the finer aspects such as this is self learned. I hope Ford has a large supply of replacements parts at the ready. Of course the way things are going now most replacement parts are sitting off the coast of California.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
You're assuming they'll replace them and not just screw on tighter and go 🤣
Bandit958
Larry
Bad Axe, Michigan
77 Bronco, 2021 F150 4x4 Sport
Same set-up my F150 has for the oil filter, Thought it was pretty simple, But I agree you
could have snapped off the broken thread and still used it.
Wanted33
Down south in Dixie
RHeinz
Ric
Houston, TX
My original response may have been a little harsh. That said, I thank the OP for noting the vulnerability of this part AND will always be careful when reinstalling it. I do not trust oil changes by others, including dealers. Once had a quick change franchise change the oil on my wife’s company Subaru. They drained the transmission fluid (by mistake) then added the full oil capacity to the engine….. Then she drove it home!!!!!!! Hard to imagine that much white smoke!!!!!
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Had to call the dealer. I believe it's the same cartridge as the f150 and ranger
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I'll let this insult slide.. You're not wrong but not right.. I think the rubber gaskets where t seated properly causing it to misalign
dgorsett
colorado
F250, Mustang, Explorer
I really don't get why they used a cartridge. My 1947 Jeep engine uses a cartridge, my son's Tacoma (and it's a PITA), all other vehicles I've had use canister, no problem, why ?
