Pinch Weld Cover-Up: Don't Use Adhesive Trim
79Ranchbird
SE Iowa
21 Explorer ST, 15 SD, 08 Mustang, 82 Mustang
How wide are the factory running boards? Do they cover full width of the SAS fender flares? Haven’t been able to find dimensions anywhere, interested in body / paint protection as much as the step.
mlsjr14
Chattanooga, TN
N/A
Anyone happen to have a link to the installation instructions?
Skeeterjack
RON
Goderich Ontario
2018MUSTANG GT
Stick a couple of painted bolts in the holes and give it a post apocalyptic,industrial,retro look.
Happy
Jerry
Missouri
CJ5, Wagoneer
Isn't the pinch weld area aluminum?
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
From what I understand, all the panels are aluminum, but the floor and frame are steel. I'm assuming the pinch weld is considered the floor. Can anyone verify the pinch welds are aluminum or steel? I really want to get the Lund rocker panel protectors, but I'm quite concerned about this area rusting. There's a lot of salt spread on the roads around Pittsburgh in the winter.
Oldgoat1-Michigan
Oakland Co Michigan
Grand Cherokee & Cherokee Trailhawk
I wonder if they're designed to leak. Basically let any moisture that gets in there have a way to get out. I'd look into that before applying anything that may seal them.
Question, has anyone else looked into having the panels sprayed. I’m thinking about having the Rhino Bed Liner application done unless the panels need to breath as discussed below. Please keep us all updated
TX-Hans
'21 Escalade, '13 Jeep Wrangler, '21 Bronco FE
I'm thinking of installing these along with the Go-Rhino DSS slider-step which on another B6G thread seem to sit a bit higher and tighter than the OEM steps. My question is, how much space is there left between the OEM step and the rocker panel protector in your setup (which looks great!)? I'm wondering if things will get too tight if I try to install both the Rhino DSS and this protector. Thanks!
Did you end up trying the rocker panel protectors with the Go Rhino DSS slider steps?
Garrett301
Maryland
2021 Bronco, 2021 Bronco Sport, 2017 Escape
I did not try both; given how the steps attach to the vehicle not sure both would have worked together without additional modification, but I could be wrong on that. In the end I was happy with the final look and will just be diligent about periodic undercarriage washing.
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim IMG_3574
CUPRA
Jared
'21 Bronco OBXSAS/'23 Camaro SS Convertible
The Trail Armor can be used with the OEM Side Steps, I just had to remove the end caps off of the steps to get the front piece of the Trail Armor installed, otherwise it was very straightforward.
Here's an install video I did of the process, if anyone is still wondering.
Tkekich
Terry
SE Michigan
2018 F150
great video!! I just picked these up for my two door.
79Ranchbird
SE Iowa
I purchased the rocker panel protector from Ford Accessories VM2DZ-1613208-A along with the Go Rhino Dominator D1 running boards w/drop step. With the mounting hardware for the running boards you cannot use the panel protectors without some significant modification. I opted to install the Go Rhino boards and leave off the rocker protection for now. It does appear the boards, and hopefully someday Rokblokz mudflaps will give good rock protection.
Garrett301
Maryland
Thanks for posting this! I was wondering about whether the two would work together. I had considered buying the rocker panel protectors to mount along with my GoRhino D6 steps but decided not to, so just mounted the D6s. Since they sit fairly high, I think they do a good job of covering up the pinch-weld. They are giving good protection now against rocks but, like you, I'm planning to add mudflaps in the future for that little bit extra.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
This pinch weld feels like a Catch22 thing for people in the rust belt... Install rocker panel=possibility of water staying trapped and rust and corrode, do nothing and the exposed weld is begging to rust and corrode ...
If these are applied before the rocker is chipped to crap they should be better than exposed metal from rock chips. If I person has chips I’d definitely seal them up before attaching these. Definitely a catch 22.
ctandc
VA
'22/23 Bronco, 96 EB Bronco
Found this thread. Just picked up our '22 BB yesterday. Factory steps. After adding bigger tires / wheels, the rocker / pinch weld area being body color is one thing that really stood out to me as "unfinished" looking.
I'm going to crawl under it tonight and check it out in detail, but from the angle the cover / rocker sits at, I'm not sure how much moisture it could really hold. Didn't even know they made these cover ups. Honestly I was just considering masking everything off and using a bedliner type spray.
But since I never used the 40K Ford Pass points I got when I bought my Mustang in '19 and we got another 40K for the Bronco - thinking about giving these a go.
MVBB
Dan
MA
2022 Big Bend
It's all aluminum
