Shrek27
Fullerton CA
Good rule of thumb is to size the DC-DC charger at 25% of your alternator's max rating. At 50A, that's well below the 25% threshold of the 250A alternator that came with the Bronco.
The nice thing about the DC-DC charger I'm planning on using (this one) is I'd be able to control the charging amperage going to my aux battery. I'll probably usually set it at 30A to keep the load on the alternator low while still being able to completely recharge my battery from 0-100% in around 3.5 hours of driving time.
Aw cool, didn't know that rule of thumb...just know that the alternator can be stressed out.
3.5 hrs to charge 100ah sounds awesome!
BroncoScotThai
Adool Ferguson
Marysville
Hyundai Palisade
Figured there was enough interest from my post in the daily updates thread that I'd break this out to share more details about this project. Kind of long-winded, but I wanted to share my thought process and journey to maybe inspire others to do the same.
First, some background...
We got our Bronco specifically for the purpose of off roading and camping trips. In researching options for gear, and how it'll all fit in the Bronco, I decided it'd be more efficient to use a 12V fridge instead of cooler that constantly needed to be refilled with ice. To do that though, I wanted a power solution that was reliable and separate from the Bronco's electrical system to avoid draining the starter battery. So it was determined an auxiliary would be needed.
After more digging, I wasn't satisfied with any of the out of the box solutions out there. Most of them are too cube-shaped and they'd need to be packed in a specific orientation in order to plug things in while on the road. I was also concerned about the longevity of these units. If something breaks, I'd be at the mercy of the manufacturer's warranty to get it fixed/replaced. Additionally, whatever I bought today, I'd be stuck with. No opportunity for modifying or upgrading components as my needs change.
On to the integrated dual battery option. There are a couple of configurations out there that hide the battery & charger in the cargo area that I was really intrigued by. I liked the ability to quickly charge from the alternator while driving and we'd be able to design a system exactly to our needs. I was certain we'd go this route, but the one nagging concern I had was the portability aspect. It'd be awesome to be able to easily take the power source out of the vehicle to our tent or around camp and use it separate from the Bronco. Additionally, if we ever (heaven-forbid) replaced our Bronco with a new vehicle down the road, I'd have to start this whole dual battery install process over again. I wanted the customizability of the dual battery system as well as the portability of a solar generator unit.
My “Hybrid” Portable Dual Battery System Design
Drawing inspiration from various solutions out there, I settled on this hybrid approach to a dual battery system with a portable battery bank. This idea certainly isn't new, but I wanted to make sure I was designing something that fit my specific goals.
The general idea is the portable power station will be charged by the vehicle while driving, which can also power a fridge or charge other devices. When camping, I can leave the power supply connected to the Bronco to continue to use it as the power source for everything. Alternatively, I could remove the power station and bring it into our tent for the night, but still have the ability to utilize the starter battery for small loads, like exterior & interior lighting.
Here's a simplified diagram of the concept:
Planning & Design
Phase I of this whole project would be to build the portable power station. It'd be something I could use immediately, before the rest of the DC-DC charging and integrated components were installed in the Bronco.
I started with the battery and case. I was targeting a 100Ah battery so I'd be good for a couple of days without a recharge. Based on manufacturers' dimensions I found a battery/case combo that I new would work. From there, I added other components that I could see myself using. I may have gone slightly overboard with trying to cram so much into a tight space, but I kept finding ways to mount/orient things within the defined area that made things more efficient. I wasn't originally even going to have a solar controller built in, but it fit and I decided it'd be convenient to have already integrated. One less thing to worry about packing. I included 2 50A Anderson plugs so I could potentially have a high-wattage charging input at the same time as outputting power to an inverter, or even a secondary battery bank.
All design work was done in SketchUp so I could visualize how all the parts would come together and insure there wouldn't be any interferences. I also wanted to design a robust frame to ensure the battery or any of the components wouldn't bounce around inside the case. There's a provision for running wires from one side of the box to the other via a channel underneath the battery, down the center. The battery is centered in the frame for even weight distribution and so I can have ports on opposite sides. I wanted to be able to have the case lay flat or stand on it's bottom edge, have things packed on either side, and still be able to access all the plugs.
I also sketched out a wiring diagram of just the portable power station so I knew going in what needed to be connected to what.
Here's the final parts list for the build. This doesn't include miscellaneous materials like the boards, wires, terminals, etc. that I had already laying around my garage.
Component​
Price​
Quantity​
Total​
Apache 3800 carrying case
$ 40.00​
1​
$ 40.00
100ah 12V LiFePO4 Battery
$ 250.00​
1​
$ 250.00
Circuit breaker$ 43.00
1​
$ 43.00
Power cutoff relay$ 12.00
1​
$ 12.00
Power switch$ 9.00
1​
$ 9.00
Terminal stud bus bar pair$ 11.00
2​
$ 22.00
4 circuit fuse block$ 20.00
1​
$ 20.00
50A fuse w/ holder (2 pack)$ 13.00
1​
$ 13.00
50A Anderson plug (2 pack)$ 12.00
1​
$ 12.00
Dual Anderson power pole connector mount$ 27.00
1​
$ 27.00
Single Anderson power pole connector mount$ 27.00
1​
$ 27.00
Dual 12v outlet panel$ 17.00
1​
$ 17.00
Battery monitor shunt w/ display$ 50.00
1​
$ 50.00
Temperature controller relay switch$ 12.00
1​
$ 12.00
Blower fan$ 9.00
1​
$ 9.00
Victron MPPT 75/15$ 68.00
1​
$ 68.00
Grand total for everything above comes out to $631.
The Build
Here are several photos of the progress of the build from start to finish. I started with assembling the frame out of HDPE boards I had leftover from another project. This stuff is awesome. It's got a lot of the same properties as wood, but the density is more consistent, making tapped & screwed connections much more secure. Plus, they come in black, so I don't have to do any sort of painting to make it all look nice.
Fits like a glove!
Cutting holes in the case and mounting all the components...
I designed the frame to be completely removable so I could easily connect all the wiring and service components down the road if needed without having to take everything apart. A strap was installed to secure the battery to the platform. It wasn't moving around before adding the strap, but I found that with the battery's weight, it was nearly impossible to lift the whole assembly out of the case without something easy to grab onto.
Wire thickness was probably a bit overkill for this setup, but it's better to be safe than sorry. Everything connected to the battery on its own circuit is appropriately fused to prevent it all from melting down.
Final assembly was a bit of a pain, just because I didn't leave much room for my fat fingers to connect all the plugs. After some minor adjustments, everything fit nicely together. The left side of the power station will be used for charging devices (phones, laptops, flashlight batteries, etc.) as well as running a fridge or camp lights. The battery monitor display is also on this side for easy access.
The right side is for connecting utilities, like my AC charger, the DC-DC charger (once that gets installed in the Bronco), or outputting to a small inverter run things on AC. There's also the solar input for charging the battery on its own. The hole cutout serves as the intake for air to get pulled in across the length of the case by the exhaust fan on the other side. The fan is controlled by the programmable temperature relay switch with the thermometer mounted next to the solar charger (because that is likely to get the hottest during operation).
The single power button on the front acts as the cutoff switch for the entire battery via the large relay. With the power off, all internal circuits are disabled and no electricity will be able to run in or out of the box. This will be useful to easily power it all down when not in use.
All buttoned up and ready to go!
Here are the high-level specs at a glance:
  • 12V 100Ah LiFePO4 battery
  • 15A solar MPPT charger
  • Battery monitor with color LCD screen
  • Temperature-controlled cooling fan
  • Single power button battery disconnect
  • 2x 20W USB-C ports
  • 1x 18W USB-A port
  • 1x 300W 12V cigarette lighter port
  • 2x 30A Anderson Powerpole ports (input/output)
  • 2x 50A Anderson plug ports (input/output)
  • 1x 30A Anderson Powerpole solar input
Next steps are to do some calibrating with the battery monitor to ensure I'm getting accurate readings and estimations for energy input/output and then it's on to field testing. I'll be sure to keep this thread updated if I discover anything new along the way.
Tdo you have all the measurements/ demensions of case and parts?
cr117
cr117
PNW
Bronco, EV6
Here's a screenshot of my frame's model in Sketchup. I may have adjusted some of the measurements as I was building it, but this should be pretty close.
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System Screenshot 2024-05-03 at 1.04.37 PM
jon
Jonathan
UTAH
2003 Rubicon, 1989 Ford Bronco Eddie Bauer
How is it holding up?
cr117
cr117
PNW
Bronco, EV6
Doing great so far, done a few cycles and haven’t had any issues. The built in solar charger is awesome. I can go from 0-100% charge in about 7 hours with the 250W panel I’ve been testing it with (outputs close to 210W). In all my testing, with the lid closed, the internal temp hasn’t gotten above 90.
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_1712
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_1711
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_1707
HotRod0369
Rod
Seabeck, WA
2023 Big Bend
Planning & Design
Component​
Price​
Quantity​
Total​
$ 40.00​
1​
$ 40.00
$ 250.00​
1​
$ 250.00
1​
$ 43.00
1​
$ 12.00
Power switch$ 9.00
1​
$ 9.00
2​
$ 22.00
1​
$ 20.00
1​
$ 13.00
1​
$ 12.00
1​
$ 27.00
1​
$ 27.00
1​
$ 17.00
1​
$ 50.00
1​
$ 12.00
Blower fan$ 9.00
1​
$ 9.00
1​
$ 68.00
The Build
Fits like a glove!
  • 1x 18W USB-A port
That is amazing. You clearly know electricity/electronics. I don’t have your skills. I’m interested to know how it works out for you. I’m doing the same as you with my Bronco except I purchased a Bluetti AC180 for power. I want to install a battery cutoff switch but not sure how to. I’m on YouTube University trying to learn. The main problem for me is which of the positive terminals do I use?
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_4804
cr117
cr117
PNW
Bronco, EV6
Figured I’d post a quick update since it’s been a year since this portable power station was built.
I’ve had zero issues with the box and it has proven itself useful in many ways. I primarily built this for tent camping to charge devices and run my CPAP during our trips. We’ve since bought a trailer with a roof top tent, which this is great to have up there at night. I’ve also used it for plugging in our 12V fridge for day trips to keep food/drinks cold. It’s even come in handy at home when we lose power. Instead of plugging in and starting a generator, I can use this power station to run a few necessary devices.
The 100Ah battery is still going strong with minimal degradation. It’s got ample charge for what we’ve needed it for. I have yet to see the internal temp get hot enough to kick on the fan. The solar charge controller has also done its job well.
The one minor issue I’ve had, and only since we started using our new roof top tent, is this thing is pretty hefty. Even with the large handle, it’s little cumbersome getting it safely up the ladder every day. However, I came up with a solution that allows me to keep the power station stored in the trailer and run a cable off one of the 50A plugs up to the tent where I can plug in this “charging box”. It’s a lightweight ammo box that I built in several USB ports and a couple of 12V outlets. Plus, it still has room for storing all the charging cables we’d need for our devices.
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_4732
Ford Bronco Portable Power Station DIY Build -- My Portable Battery System IMG_4736
CalvinT
Calvin
Phoenix, AZ
It all depends on what you're trying to accomplish. Do you want to kill 100% of the power from battery or just some of it? Bear in mind that if you want to kill all of it, you'd have to have a switch that could handle current to your starter. Other than a winch it uses more current than anything else that might be on a Bronco.
jdmyron
Jonathan
US
Really impressive build, level of detail here and great work.
I took a slightly different approach:
I have a Jackery 1000 v2. It's fantastic for keeping my ICECO fridge running nice and cold but recharging it off the car was maddening off the traditional 12v connector these vehicles have and added anxiety for multi-day overlanding/camping trips so went with the following approach:
- Ran a new electric line (heavy, 6 gauge) from the battery to the rear cargo area (through the firewall, hidden under the moldings to the back)
- Included a fuse between the battery and the line
- Added a relay to be able to activate the line from a 10 amp built-in aux switch
- Added a step-up converter to bump the 12v to 24v, that's really key here
I was thinking of doing an inverter or something like that for AC charging but seemed silly to convert AC to DC just to get it back to DC for the fridge.
Now I'm charging the Jackery at 400w which is awesome and stays way ahead of the usage from the fridge with usually is < 50w and doesn't run continuously. And the way it's set up it automatically shuts off the 24v line when the car is off and the Jackery just takes over on it's on at that point.
Most of the components are quite inexpensive but obviously the most expensive part of all this is the Jackery itself. However it's such an incredibly capable and flexible device that it's been worth it.
