Proper TORX Bit to remove Rash Rings from Sasquatch package wheels
FATHORSE
Stephen
okc
nissan
Thanks to you guys I learned that I got the wrong torx bits to remove my rash rings.
Thought I would make a public video to help others educate the correct ones to get.
Let me know if I dont need to quit my day job.
I may try and make more videos if I get a good response.
Thanks
vrtical
Doug
GSMNP, TN
Fords
I think investing in an impact driver would also be a plus.
604Bronco
British Columbia
www.bronco6g.com
Thanks for posting - any link to share on the proper set? Likely should buy one now…
Edit: Disregard; I came across another post by you with the set (I’m not a stalker, I swear).
I just ordered the Neiko set now. Appreciate it!
Ford Bronco Proper TORX Bit to remove Rash Rings from Sasquatch package wheels 1636641921414
Edit #2:
Here’s a side by side comparison, for reference:
Ford Bronco Proper TORX Bit to remove Rash Rings from Sasquatch package wheels 1636642038540
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
You didn’t mention why one set over the other? The Torx Plus I believe has slightly more squared off edges to the wings. Was the other normal torx bit stepping out when you tried to use it?
Lifeliberty
Moonbeam👀
Columbus, OH
Thanks for this info
FATHORSE
FATHORSE
Stephen
okc
nissan
Yes sir, the star pattern on the Reg torx tend to slip and strip. I could have done a better job at explaining the reasoning for sure.
FATHORSE
FATHORSE
Stephen
okc
nissan
I just got through dropping off the Rash Rings for Powder coat, will post pictures when I get them back in a week.
Excited to see how they turn out.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
The Neiko's work but man that's some Harbor Freight quality control they got going on.
FATHORSE
FATHORSE
Stephen
okc
nissan
Ive had a tire and wheel guy strip the thread in my lugs with improper Impact driver usage.
Figure I will always play it safe.
FATHORSE
FATHORSE
Stephen
okc
nissan
Are you using a torque wrench to take them off?
The only thing I had to get some weight on the bolts. Everything else was small hand size tools.
What would you recommend to use?
shotgunfatcat
WI
2022 bronco
If it is all you have, use it. It is just not the best for torque wrench calibration. Taking off those bolts will probably never throw the thing out of calibration, but using it to take off a tire will.
If you are going to want to make youtube videos, which the more the better in my opinion, maybe get a 1/2 socket set! You would get eaten alive in the youtube comments for using a torque wrench. Not trying to be a jerk or anything, just constructive criticism. There is plenty of things I do that isn't right. :)
FATHORSE
FATHORSE
Stephen
okc
nissan
Thank you for the advice!
I appreciate it, the wrench is really old, so it’s kind of a all usage tool to me. Would never use it to be dependable. Plus, aren’t bad comments just as good as good ones on YouTubes! Lol.
