Proper TORX Bit to remove Rash Rings from Sasquatch package wheels
SPITmadFIRE
CA
The only thing I had to get some weight on the bolts. Everything else was small hand size tools.
What would you recommend to use?
It's typically never recommended to use a torque wrench to break bolts free, or back them out whatsoever. This will slowly but surely throw the calibration of the wrench off. Use a breaker bar for breaking bolts free, and a ratchet to back them out.
Lifeliberty
Moonbeam👀
Columbus, OH
https://www.teamtorque.com/torque-wrenches recalibration
"The actual "Click" from a wrench is considered a "Cycle" of that wrench. Most manufacturers recommend click-style torque wrench calibration after 5000-to-7000 cycles.
For most customers, this means you should calibrate and test torque wrenches every 12 months. "
jasonkosi
Jason
Chilliwack, BC, Canada
shotgunfatcat
WI
2022 bronco
I use my torque wrench once every 12 months. :)
Lifeliberty
Moonbeam👀
Columbus, OH
Yeah, mine sit for years at a time. Mostly use for motorcycle stuff, steel bolts in aluminum. For storage i turn to lowest setting
RyanP
Ryan
Maryland
Mazda CX-9
Thanks for posting - any link to share on the proper set? Likely should buy one now…
Edit: Disregard; I came across another post by you with the set (I’m not a stalker, I swear).
I just ordered the Neiko set now. Appreciate it!
Edit #2:
Here’s a side by side comparison, for reference:
Does the set shown cover all of the sizes needed and what are the sizes that we need? Thanks.
FATHORSE
FATHORSE
Stephen
okc
nissan
FATHORSE
FATHORSE
Stephen
okc
nissan
The size for the rash ring bolts is tp-40. The others for the roof and bronco bolts are included in the tool kit that comes with your bronco.
shotgunfatcat
WI
2022 bronco
Sorry I derailed your thread a bit, I honestly am happy to know how to get these off now. I don't think I have any torx plus and wouldn't of started with one. 😆
FATHORSE
FATHORSE
Stephen
okc
nissan
I do like adding tools to my collection, and I’m definitely not a expert as you can see.
FATHORSE
FATHORSE
Stephen
okc
nissan
hey that is why I post it here, because I have learned a lot from the people on this forum. And I’m still learning! I appreciate the comments and camaraderie.
vrtical
Doug
GSMNP, TN
Fords
Ive had a tire and wheel guy strip the thread in my lugs with improper Impact driver usage.
Figure I will always play it safe.
I am not talking about a Snap-on 3/4, you can look at getting a 1/4 socket impact something that isnt going to send the bolt through the tire :) You can also add in a torque extension to manage it.
