Question on Audio upgrade
Sherminiator
CNJ
2022 Ford Bronco Big Bend, 2024 Bronco Sport Big Bend
DividedSky
M6
I think this is only of use if you are adding a sub... someone can correct me if I'm wrong there.
If you are adding a sub, I think its a must-have. This controller came with my wiring harness from PlugNPlay kits. I figured what the heck and installed it as it is easy to do at the same time you are running wiring for a sub to rear of the vehicle. I use it quite a bit - i need different bass level for XM radio vs. streaming Spotify vs. regular radio, and even need different level from one XM station to another. If you are wiring for a sub, I say go for it.
cmcbronco
Illinois
2012 f-150 FX4
If you’re running the key 500.1 then yes. Very handy to have and I’ve installed the bass knob on the last couple installs I’ve done. I wouldn’t go without it now!
Ford Bronco Question on Audio upgrade CFCD5ADE-BD77-4D83-A56D-B50932BD0B4D
Wannabe Techie
Chicago
My head unit controls my subs so it's not necessary but if you like instant access to control it, it's nice. I have to go into the controls and go through the screens in order to control bass so it can be useful to keep it separate.
BTW, Kicker Key is awesome... will blow away the stock and the B&O system once you hear it.
deanosf
dean
bronco
So, I read everything about b&o upgrades and such, then did the 5 speakers. Without an amp upgrade. I have to say I am super pleased with the sound after replacing the 4inch all around. I also did it in around 1.5 hrs in my driveway. I found it relatively easy to do. You might consider doing the before installing amps
Burgler2112
Andrew
2022 Black Diamond Bronco 2.3l Mid Soft Top
What do you have plugged into the USB?
Sherminiator
Sherminiator
CNJ
Thanks guys-I’m replacing all the speakers and getting the B&O sub enclosure (replacing the speaker it it with a low profile kicker sub), so I’ll add this to the list of stuff I need.
Burgler2112
Andrew
Those are my headphones lol. The other cord is for my phone mount charger.
Lol. I thought it was a hard drive or something.
