Quick Question, but what would a 4 Door Sasquatch Badlands have over a 4 Door Sasquatch Black Diamond?
WuNgUn
Ontario Canada
2 door Squatched
I don't get why the auto 4H transfer case is an "upgrade"? So basically it's gonna behave like my Escape does in auto mode?
I think the manual T-case is the enthusiast option. Or am I missing something?
If high pack was available on the BD and the sig grill, I would of definitely picked it over the Badlands.
I wasn't considering Squatch, which is what drew me to the 33's of the BL...
But reality is, the web images of those 33's look way better than what you actually get with the 33's...skinny, anemic looking KO2's.
So BD with Squatch isn't off the table.
Squatch
Miami
My suspicion, given that I randomly woke up just now, is that the advanced transfer case is part of the Sasquatch package and has yet to be mentioned officially.
My reasoning is simply that it is available on every trim level. Why would they have a component as significant as a transfer case optional on the Base? It's more reasonable that it's part of a package and the Base is very limited in package availability. What package is available on the Base trim? Sasquatch.
WuNgUn
Ontario Canada
2 door Squatched
When is having an extra tool available not an upgrade?
"Tool"? Or something else to break? In the middle of nowhere...?
Then again, it's probably just a software unlocked upgrade anyway. $$$
TXRancher
Brownwood TX
2011 F150
You mean software can change the ratio of the transfer case? That would be something.
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Dana M210 Front Axle standard on the BL and Optional on BD.
tracythemighty
Tracy
U.S.
2022 Ford Bronco - Race Red Base w/Sas
I'm not an off-road enthusiast so the sway bar disconnect has little value to me (other than just having it in case I do start off-roading or for resale if I ever sell)
So for me the biggest difference is the ability to add the high or lux packages. I'm probably going to be content with a Sasquatch BD with the mid package...but I'm definitely planning to spend a lot of time in B&P to review all my options.
I was torn between the two, but I finally decided on BL because once I added everything to BD, I figured it wasn't that much cheaper. Plus I didn't want to give up the high package. I already ordered, but I still wonder if I am making the correct decision going with the BL. I'm old and a complete newbie, so I'm not sure how much I will ever off road. In my mind, it will be enough to make the higher price worth it.... lol
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
Roger123
Roger
VA Beach, VA
Roger123
Roger
VA Beach, VA
This is something I am wondering about for B&P. The upgraded t-case is optional on the BD. So it is available just how and how much? Since it is listed with the powertrain items I am assuming it is a stand alone option and I think the survey had it as 1k but I may be wrong.
Not a huge deal as with the manual trans it seems the crawl ratio with the std case is about 80:1 and with the upgraded case it is 94:1. Awesome either way but just wondering what B&P will show.
It's an additional $750 on BD, standard on BL.
Roger123
Roger
VA Beach, VA
I really want the upgraded Transfer case, that 4A mode looks perfect for my needs.
Agree, after owning a GC I wouldn't have a car without it (4A that is).
Roger123
Roger
VA Beach, VA
I would prefer to have the upgraded t-case but it is not a deal breaker for me at this point and looking at the performance numbers it is not a huge negative overall. I go from it being a eh upgrade to a "I need" or "I want". If it is 1k extra...that is less than $20 a month or just add an extra 1k to the down payment...I keep telling myself...lol.
Comparing to the Jeep rubicon the bronco std t-case puts you between the top two crawl ratios I think around 80:1 or 3:1 +/- from the top/bottom of the rubicon combos. It is not like it drops you down to the 50-60:1.
Will 100% be working that aspect in the B&P.
The only thing I am 100% all in on is the A51 paint.
Advanced 4x4 is more than the crawl ratio. It allows the vehicle to be all wheel drive all the time vs. rear wheel. In my opinion it is a HUGE advantage over a standard 2/ 4 wheel system.
It really makes the car feel very stable in all road/ weather conditions. It's been a minute since I've driven a short wheel base rear wheel drive vehicle on 33's (2011 Wrangler) but all wheel drive is nice.
BroncoRevital
Zak
Toyota Tacoma, past; 94 FB, 86 FB, 84 Bronco2
Did you price out the Outer Banks? Sounds like that might be more suited for less off-road features and allow for high package.
BroncoBC
Oregon
Soon to be a Bronco
The downside to all wheel drive is tire issues. Let say you cut a sidewall on a tire that has 15000 miles on it. If it’s all wheel drive you have to replace all 4. If it’s manual then changing 1 will be fine or a pair. Far cheaper
