Replace 2 Maxtrax MKII Boards with 4 Maxtrax Mini Boards?
BroncoTrail
Salt Lake City
2021 Badlands Sasquatch Lux
I have two Maxtrax MKII Recovery Boards. Because of their length, they only fit behind the 2nd row of seats if I put them at an angle, which annoys me. And I don't always want to have the seats down and I don't have a roof rack to mount them to either.
So, I was thinking of buying four Maxtrax Mini Recovery Boards and keeping them in the back instead. They'll be easier to store and organize.
What do you think? What am I really losing if I go with shorter recovery boards?
Theherofails
Thomas
Phoenix
I have both and they are useful for different terrain. I don't consider the mini boards to be a particularly strong stand in, but it depends on how you use them. The shorties are good for loose material as you generally just need a bite of traction to get moving. The big ones are good for bridging, deep mud, getting off a rock stuck under your skid plates, etc.
A recommendation on how to travel with your Max 2 boards.. I do it 1 of 2 ways depending on how I pack for the trip. If I want them inside, I use long velcro straps and hang them from the rear head rests. I have seatback protectors on my rear seats so I dont worry about the rubbing but you may want to just put a towel over it. They hang nice n loose and don't rub anywhere else. You can also get access just by dropping both rear seats and folding them forward.
Ford Bronco Replace 2 Maxtrax MKII Boards with 4 Maxtrax Mini Boards? IMG_1582
The other easy option is using a few straps to hook the MaxTrax to the spare tire and keeping it out of the vehicle altogether.
BroncoTrail
BroncoTrail
Salt Lake City
I think I am a little retarded for not thinking of this in the first place LOL. Anyway, you just solved my problem. They fit perfectly in this spot. I may also try hanging them like in your photo. I'm going to get the storage bag from Maxtrax though so that if they're full of mud, it doesn't get all over the inside my vehicle.
Ford Bronco Replace 2 Maxtrax MKII Boards with 4 Maxtrax Mini Boards? PXL_20230324_230944927
Thanks!
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Theherofails
Thomas
Phoenix
Ford Bronco Replace 2 Maxtrax MKII Boards with 4 Maxtrax Mini Boards? IMG_0176.HEIC
Thanks!
Get some seat back protectors as well.
https://www.amazon.com/Mabett-Backr...mzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
They're pretty affordable and they work GREAT for what they do.. Carpet on the back of the seats was a terrible idea from Ford. Just held on by velcro.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
If you are looking for some MaxTrax let me know. We stock the product.
What I used on our demo truck was the GoTreads. They fold up and tucked behind the rear seat but expand to the full length of a regular traction board. Sold as pairs:
https://www.4x4truckleds.com/other-truck-accessories/recovery-gear-jacks/
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
The problem of storing them inside is once you used them in mud you won’t want to put them back inside, I know this from experience. And you really don’t want to have to fish them out when you need them fast in an emergency.
If you don’t have a rack, I suggest mounting them to the spare tire.
This one is Overland Kitted, but I suggest Rock Slide Enginnering’s as it’s much cheaper and just as effective.
BroncoTrail
BroncoTrail
Salt Lake City
Ford Bronco Replace 2 Maxtrax MKII Boards with 4 Maxtrax Mini Boards? IMG_0918-XL
Interesting! Do you have any concerns with the extra weight that the gas can and the recovery boards are putting on the tailgate?
emulous74
Seth
I am because I’m carrying 4 Maxtrax Extremes and they are heavier than the standard ones and 3 gallons of gas. I ordered a tailgate stiffner and raptor hinges, I only have 33s so I’m not really over the weight limit, but why not do as much I can to stop a problem.
I have since changed out to TraiRax PaxRax and carry my recovery boards on that and will only carry gas or water on the spare when I think I’ll need more than the PaxRax can carry..
If you have a four door take a look at their half rack, I think you’d get more out of your money as you can use it for carrying other stuff and down the road you can add their PaxRax to that to carry more.
KABQ
Aaron
Albuquerque, NM
I have the Rock Slide Engineering one and it's pretty sweet. How were you mounting your traction boards to yours? I was thinking about making a big long bracket, but might not spend the time if there's a cheap solution out there that already exists.
emulous74
Seth
I went with a “universal” traction board plate, this way I can also mount them easily to my roof rack on my other vehicle. But you will need to see if the holes in the board will line up with the spare tire mounting plates. Unfortunately they aren’t cheap at around $200-$300 dollars and you’ll also have to fork over money for mounting pins for your specific boards.
