Heard that max volume can work as a standard sound deadeningSo throwing out some technical questions. I really don’t know if anyone has the answers. Maybe those that are more familiar with the assembly of cars have a better guess...or those who work at a Ford plant could chime in @LEGEND
1. Do you think the rubber floors have any level of sound deadening underneath, or does the rubber itself have sound deadening properties? Perhaps it results in a quieter cabin for all I know
2. I presume in a build with carpeted floors there’s a thin layer of sound deadening. The high package adds additional sound deadening so I wonder if this carries over to the floors as well and there is a level 1 and level 2 sound deadening under the carpet?
3. If above is true is this also carried over to the rubber floor option or is it deleted entirely? If neither level of sound deadening makes its way to the rubber floor that means a carpeted floor with the high package is even that much more quieter than a bare rubber floor??
I also would like to know the answer to this question. I want a badlands. But I also don’t want a loud Bronco.
I may have to consider an outer bank.
Normal sound deadening for car audio is made from Butyl rubber and a thermal aluminum shield. My guess is the harder rubber used in this will reflect sound more then absorb but doubt it will be much different from the carpeted floors.Carpet absorbs sound while rubber (and other hard, solid surfaces) reflect it.
Rubber can be used in sound-proofing, as long as there is no sound going around it (e.g. a sound-proof chamber). Carpet helps to stop echo (think acoustic panels in a recording studio).
Minimizing the echo with carpet would make it significantly more pleasant to ride in, but wouldn’t block the sound.
Recording studios often use a combination of both. There is sound-proofing rubber lining that is used inside walls and inside cars (here’s an example: https://www.acoustimac.com/soundpro...MIje7hzKrh7AIVE47ICh1_GgygEAQYAiABEgJi-PD_BwE). Then there are different types of materials that can be used to stop echo (like carpet for example).
So the rubberized flooring with carpet on top would provide the best experience in terms of road noise (as well as conversations and listening to the radio). But if I had to pick one or the other, I would pick the carpet since minimizing the echo can really make the sound more bearable and the rubber insulation wouldn’t make as significant of a difference.
The rubberized flooring probably won’t make much difference. It seems like a thin layer is painted on.Normal sound deadening for car audio is made from Butyl rubber and a thermal aluminum shield. My guess is the harder rubber used in this will reflect sound more then absorb but doubt it will be much different from the carpeted floors.
If you want some noise reduction with the outer banks, you may be able to get those snap-on carpets that most cars come with. I imagine the bronco will have that for other trims as an option of either the rubber mats or carpet mats, so it may be available after purchase to put over the rubberized flooring (assuming the rubberized flooring has those snap points for a rubber mat over the floors rubber coating).
There will be plenty of aftermarket options for sound deadening panels for the hard top. Even if there wasn't it's pretty easy to DIY with dense sound deadening foam.And if you go with a 4 door badlands and opt for a hardtop you can not get sound deadening for the hardtop.
so no carpet with rubber floors and no sound deadening will prob make the badlands pretty loud.
#facepalm #wasntthispartofthewashoutinteriorthread?If you want some real noise reduction in keeping with the retro Bronco theme then Shag carpet everything Floors, headliner, dash.....shag away
The carpet will most likely have padding and if you option the package with additional sound deadening, it would be even thicker and on the firewall as well. If you also get the roof sound deadening, it should be relatively quiet.I would guess that the rubberized flooring would provide little, if any, sound deadening. It will probably be too dense to absorb any sound waves. It
I would also guess there is not going to be any kind of material that could soak up moisture between the rubber flooring and the body of the vehicle. It'd pose too much of a mold/mildew risk. So, I dont know if there would be any type of sound deadening material under the rubber.
On the other hand, I'd guess the carpeting is probably not going to be thick enough to absorb any sound waves either. Best case is that it prevents sound waves from reverberating.
In sum, the Bronco is likely to have a loud interior.
