Rock Rails
Offroadready
Ter
Manchester
I hope you get yours early and they get right on it. I want SOS sliders.
The only changes I will make from the ones I have now are to get the plates welded on the top like yours. I really didn't think about it when I got mine, but the sliders with the openings are dangerous to my dogs. I'm paranoid that one will get their leg caught in it jumping in or out.
I second this. One of our dogs did get their legs caught in the opening. It was terrible. We are now getting plates welded on top.
Brongo
Here and there
Sure we're not looking at the step bars?
Ford says each rail can hold the entire weight of the truck.
I was going to say the same thing. No way the body is going to support a rail that is supporting the weight of the truck.
Escape Hatch
Mk7 GTI, 19 Atlas SE w/ tech R Line V6 4 motion
Ford says their rails will hold 1.5 times the weight of the truck. I will still add rails anyway.
NCOBX
H2 Hummer, Holden Commodore
Attached pic is of my factory rock rails, I think Ford should have went this direction over body mounted rock rails - makes no sense.
Brongo
Here and there
Ford Bronco Rock Rails 29883D2C-D192-4013-A08F-2E829743713F
That's definitely the real deal right there. Def makes no sense that Ford would do it differently for their newest off roader.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
I effing love the sliders on my Tacoma being that its a fat trail pig that feels like it has a 500" wheelbase...
Very early on I am going to add frame mounted sliders that are stronger ad that stick out further to provide some margin when your against a tree/rock and leaning over.
Ford Bronco Rock Rails 1613170469274
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
Nothing wrong with a good body mounted rail/slider. Just a matter of having them be thick enough and designed in a way that the load is spread out evenly among the mounting points.
The rocker guards below have 6 bolts on the side and the bottom is sandwiched between the body and the body mounts. It is sturdy as hell.
Wave your tire in the air like you just don't care
:cool:
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
Do frame bolted rock sliders require drilling or do they take advantage of existing holes? I'm new to this so assume I know nothing. Because I do.
