- Mike
- Apr 15, 2021
- 5
- 180
- 593
- Memphis, TN
- 97 TJ
- First Edition
Nice write up. Thanks for sharing. I’m very much on the fence about doing the install myself.The wiring is a piece of cake, the interior trim panels pop-off easy and you can fish it thru with a stiff wire between the doors and up under the dash and yes there is a bracket for the supplied switch (you want to use the supplied switch so it is on all the time the aux switches are only on when key is on) as far as the step sliders themselves you will need help or a jack to hold them up till you get the bolts started ( I have a lift in my garage and used a transmission jack to line them up) but they are really not that heavy and with and extra hand or two it shouldn't be a problem.
All the hardware comes with the set and the whole experience from the packaging, shipping, materials, wiring, hardware and the instructions is all first Class, and the end result is awesome the fitment and the operation of the steps are perfect.
