Show us your installed wheel / tire upgrades here! (Pics)
Victoryengineer
Rob
Northern Michigan
Kubota 7040, Polaris 570, Victory MC, Silverado
22 Badlands Sas
Updated the stock set up finally to
17x9 method mr312 -12mm offset
tires
35 bf ko2s
gotta ride feels better and rides quieter I love
the way it came out and stance I was looking for.
Those look great on your rig.....well done! It's hard to go wrong with Methods :)
Jhuff
J
Toyota Tacoma and DR650
How hard was the install
The first time took most of a day, but I wasn't in a hurry. How "hard" the install is depends upon which method you use.
Dropping the LCAs (only) was pretty simple; until the very end when I was sore, tired, and trying to get them back in and torqued. I swore I'd never do it again at that point. 😂
If I didn't have an impact gun, I would've been swearing MUCH more.
Here's a small discussion some of us had about the install, and it sums up my experience well: https://www.bronco6g.com/forum/threads/any-shortcuts-for-installing-lift-and-levelling-kits.44441/
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Fuel block wheels and possibly a huge mistake fuel gripper MT that took a ton of weight to balance. So seems like they might be not great tires. They are fairly quiet and ride ok for now.
Ford Bronco Show us your installed wheel / tire upgrades here! (Pics) 1B09079F-3AF1-4AE3-B191-6BDD32F69995
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
Looks great! What wheels are those and what tire size did you go with? Also, which step rails are those? Thanks.
Wheels are Ultra Mongoose 17x9 25 mm offset, tires are BF Goodrich 285/70r17 KO2,
The running boards are Go Rhino D1.
I had to cut down the D1's by 14" and weld them together, from the 4 door ones, they didn't have 2 door available when I installed these. I believe they do now.
I used the OEM hub covers from my Base steelies and drilled and tapped the rims so the caps would work.
Thanks,
StephenSJ
Stephen
SoCal
Outer Base Diamond
Thanks,
Got it. It all comes together perfectly. Nice job! I will have to look into those D1s for a 2-door. Thank you.
Jsullivan
Jay
I checked and GoRhino has a 57" D1 running board available.
That is for the 2 Door. Mine were cut to 60" long.
Part #D10057T
The brackets I ordered were #D64129TK (for 4 door-I don't see a 2 door kit yet)
You'll have 2 extra brackets and some nuts and bolts but they bolt up great.
StephenSJ
Stephen
SoCal
Outer Base Diamond
Part #D10057T
Cool, thank you for the info! More accessory items to pile up as I patiently await my Bronco (wife not happy, lol!).
Baseaf
Base Bronco
16x8 0 Offset Vision Turbine on 285/75/16 Nitto Terra Grapplers.
TXArea51
Juan
Lumberton
FORD Bronco Big Bend SAS
I was going to attempt it but, I gave in and going to have my local shop do it. I’ve done plenty of lifts on Tacomas and 4Runners. Just don’t wanted to risk it.
Demosouthpaw
J
T A M P A
B R O N C O
Anthony
Charlotte
Audi Q7, Jeep Cherokee
Just letting you know, you inspired us! We did the same thing but went with Cooper all terrains since this will mainly be a daily driver. Thank you so much!
Ford Bronco Show us your installed wheel / tire upgrades here! (Pics) 20220528_142846
Looks amazing! Glad the post was helpful!
