skid plate question
DREWR13
DREWR13
DREW
ATLANTA GA
2003 Miata....
Ok I see what you're saying. I like the JCR but it's unfortunate that it doesn't work with the factory engine skid.
Hmm Aluminum would be nice though.
dgorsett
colorado
F250, Mustang, Explorer
The thing about skid plates is no matter what kind they are the make the area you want to protect even lower and more subject to hanging up. On my 2.3 I don't have the K braces and everything , vital is tucked pretty well. I did go ahead and order the transfercase skid. The worrisome thing is the transmission, though nicely tucked that plastic pan is subject to a rolled rock or limb. I'm thinking of a home built skid that kicks up in front of the crossover pipe and mounts to the sway bar bolts up front.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
This is the damage I'm trying to limit btw. Oh and ignore the dirt, haven't figured out a way to clean under it yet :)
You can just cut them off, my bronco didn't even come with those bars. Looks like they are part of the factory off-road protection. Going to be interesting if these companies take those cross bars into the design between different trims
Ford Bronco skid plate question PXL_20220506_165625308
dgorsett
colorado
They only come on the 2.7L. Maybe the engineers thought the frame needed strengthening with all that power!
DREWR13
DREWR13
DREW
ATLANTA GA
2003 Miata....
oh damn, I had no idea those braces weren't on all the Bronco's. I'm not as worried about abusing them then. Seems like you could cut them out and just get some flat metal skid there.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Actually looks like it wouldn't be to hard to do, you could weld straight to the braces as they un-bolt with the cross member.
RubiconSasquatch
Josh
Denton, TX
2022 BadSquatch, 2021 JLUR, 2008 JK-X, 65 Elco
Honestly man, these don’t look very damaged at all. It looks like they are doing exactly what they are designed to do… and I’d bet will be way cheaper to replace than an aftermarket skid plate will be, if you do get them really mashed up. Maybe a little rustoleum to make you feel better about their condition? I’d honestly just leave them as-is
DREWR13
DREWR13
DREW
ATLANTA GA
2003 Miata....
Yea honestly once I realized they aren't even on other trims I'm way less worried about bashing them up. A skid would prob help with not getting hung up on stuff though.
Bronco1988
Vinnie
Sasquatch Bronco
Which transfer case skid did you go with? Do you have any pictures of it installed?
dgorsett
colorado
Ford, shipped not received yet.
BTW $40, fom village ford. I'm going to make a reinforcing bracket like asfir
Bronco1988
Vinnie
Sasquatch Bronco
Oh wow! They sold you just the transfer case skid? Village Ford in Dearborn Michigan?
dgorsett
colorado
Yes. I bought the engine skid, transfercase skid and rear tow hook for about $250 shipped, hasn't arrived yet. Shipping is a killer, but still cheaper than most
Bronco1988
Vinnie
Sasquatch Bronco
Awesome! I'm going to call them now. I have the front skid and engine skid. Just need the transfer case skid.
dgorsett
colorado
BTW I don't think they come with bolts, but I figure I can get that at the hardware store.
