Soft top issues - wind noise from my rear passenger door at 40+ MPH
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
I don’t have the soft top, but I do notice this same thing with the hard top version as well. Any advice? I know the hard tops have been plagued with wind noise, but it’s interesting I feel like this is the exact description of what I’m hearing as well from that rear passenger.
Hi there, Jason! Will you send us a PM with your VIN and dealership name/location? I can look into these wind noise concerns on my end. To send a private message, just click on our username and select "Start Conversation".
El Bronco Blanco
Matt
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
Ashley
Ashley
Evans, GA
Kia K5
I have the same wind noise but I have noticed it with both my softtop and with the hardtop. What would cause it with both tops?
Ashley
Ashley
Evans, GA
Kia K5
Sorry to necro this thread, but did you ever find a solution? I just got my '23 a few days before Christmas and I have this noise exactly as you describe it. For reference, I drove a '21 soft top for 9 months and never heard this much wind noise. Not even close.
I have the same issue too and can’t seem to find a cause. The dealership said they can hear it but they can’t find a cause either, just that some tops have more noise than others.
Potroast_Jr
Louisiana
2023 Bronco
Yea, I gave up on my local dealerships helping. The cause is the top is just loose in that area. My bracket isn't a problem, there's just too much slack in the top in that spot.
I went with the homemade headliner route with a sunshade net and a mattress topper. It keeps a ton of heat out in the summer, and completely negates the wind noise from the sides.
Ford Bronco Soft top issues - wind noise from my rear passenger door at 40+ MPH 1710947258625-02
Ford Motor Company
Dearborn
Hi Ashley! I can look into your bronco's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your bronco's VIN?
jorgem31
Jorge
Tampa
Has anyone gotten this resolved?
I thought I was headed in the right direction when the dealer replaced my top recently, but they only replaced the fabric and not the frame which is obviously where the intrusion occurs. The newer fabric has ridges built in which help tremendously with water channeling onto you when you open a window, but I still have the same wind noise I had before. What's worse is now the top flaps when driving on the highway. Taking her in next week to see what they can do.
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Everyone asks if it was latched properly, but you also should check that the bracket is adjusted properly. The bracket where the top latches in the middle can be adjusted forward and backward to snug things up. Worth a try.
Dmorty217
Derek
Venice FL
Camery
I had to have my passenger side cable replaced due to wind noise and the tension not being there when closed. I could lift up the top where it meets the roll bar. If the middle is latched, the windows are installed correctly then this is what I would look at next.​
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
And them ignore him like you did to me?
