Pull the window entirely out and put it back in, that should fix it.
Agreed - if you've never taken the windows out you'll see that you can fix this issue by removing/reinstalling. Something's pulled the part of the window that folds behind the seam of the Bronco out so it looks like it's splitting but you should be able to fix no problem.Pull the window entirely out and put it back in, that should fix it.
Thanks I havent, was cold here, never had a soft top eitherthat just looks like you need to reseat the side window into the groove in the back window. I am guessing you haven't taken the rear windows out yet. You can kind of pull/push that back into the groove, then pull the Velcro side back down and reseal that also.
That black plastic piece feeds into a groove and is what looks the side window into placeThanks I havent, was cold here, never had a soft top either
