**SOLVED** Hard Top Is Stuck - Won't Come Off!
StephenSJ
Stephen
SoCal
Outer Base Diamond
I've had my 2 door Base for a little over a month now and finally got around to taking off the front sections of the hard top for the first time this weekend, however, it was not meant to be. After releasing each of the latches, all areas of the driver's side section release from the vehicle except for the area above the front center latch (the latch closest to the center console where the aux switches are). Same thing is also happening on the passenger side.
Any ideas as to what might be going on? Hoping it's something stupid that I just overlooked, and I'd like to resolve myself without going to the dealer, if possible. Thanks in advance.
Blaven
Pennsylvania
Yeah thats weird. They shouldn't be giving you any problem when turning them. Are you sure you're turning them the right way? 😄
StephenSJ
StephenSJ
Stephen
SoCal
Outer Base Diamond
Lol, yes I am sure. It's like that center area is fused to the vehicle/not releasing.
Mortonm
Canada
2022 Ford Bronco Black Diamond
Mine has been only off twice and a couple times it stuck there a little. Give it a bit more of a pop and it should come up.
Mortonm
Canada
They also come off in a specific order. Make sure the driver comes off first. It sits over top the passenger
604Bronco
British Columbia
www.bronco6g.com
Just give it the ol' Mario punch, eh?
Ford Bronco **SOLVED** Hard Top Is Stuck - Won't Come Off! 1668398825590
StephenSJ
StephenSJ
Stephen
SoCal
Outer Base Diamond
I may or may not have utilized a rubber mallet at one point (don't want to void warranty).
Mortonm
Canada
Double check the order you are removing them. It matters.
StephenSJ
StephenSJ
Stephen
SoCal
Outer Base Diamond
Yes, I am aware of this. Thank you.
StephenSJ
StephenSJ
Stephen
SoCal
Outer Base Diamond
This sounds like a waxing issue.
I haven't washed it yet other than cleaning the wheels with some wipes, lol. Unfortunately, haven't had an opportunity to drive her much.
Tilzbow
NV
GM Sierra Diesel Pick Up
Sorry but I’ve got to ask a dumb question since I made the same mistake... You’re releasing all four latches, correct? (Three turn and one is a leaver.)
604Bronco
British Columbia
www.bronco6g.com
You're not driving a Bronco Sport, are you? That roof is not removable.
Sorry - Couldn't help myself.
StephenSJ
StephenSJ
Stephen
SoCal
Outer Base Diamond
Not a dumb question, but yes, I'm releasing all 4.
Tilzbow
NV
Gotcha! FWIW the weather stripping on both of mine were a little sticky the first time I took the panels off and I had to pop them lightly with my fist a few times to initially break the seal.
