- Travis
- Jul 13, 2020
- 22
- 825
- 1,331
- Los Angeles
- Alfa 4C Spyder, Ducati V2, BMW X1
- First Edition
Th HOG is going to make the Jeep 392 look silly.
maybe but the 392 makes the hog sound silly.Th HOG is going to make the Jeep 392 look silly.
just in time for biden's new oil regulations and higher at pump pricesIt will be a lot more than a loaded FE .... A LOT MORE!!
If Ford and Jeep are competing toe to toe then the Hog should get Ford's Twin Turbo small block V8 jammed in there somehow!
You might have read that one of the engineers had on his linked in page that he was working on the 2021 Bronco and 2023 Bronco Raptor. (The engineers page got changed shortly after his profile was on the forum here) That is the only place I have seen mention of it being 2023.
Last winter to spring, here on the forum, it was referred to as the Raptor Bronco, then it got shortened to the Braptor, then a little birdie leaked the code name Warthog.It's been a while back. I thought I saw it here on the forum somewhere. Is the Raptor Bronco and the Warthog two different things? Am I confused on something. Or did it start out named raptor bronco?
So Ford Stig said the tooling guys were given a year to get the tooling modified for the Hog. So time line wise I see some units being 22 and the rest 23s and long as no hiccups. Tooling has to be taller! Bc Judy got the booty and legs!Rumor Iāve seen is they moved it up and it is likely a ā22 model now. Iām curious to hear what the Ford Stig says
Interesting. So 16,000 produced to be split in same way or another between 22 and 23?So Ford Stig said the tooling guys were given a year to get the tooling modified for the Hog. So time line wise I see some units being 22 and the rest 23s and long as no hiccups. Tooling has to be taller! Bc Judy got the booty and legs!
Thatās awesome! So late ā22 or ā23s ???So Ford Stig said the tooling guys were given a year to get the tooling modified for the Hog. So time line wise I see some units being 22 and the rest 23s and long as no hiccups. Tooling has to be taller! Bc Judy got the booty and legs!
